(#301)
BevsM3's Avatar
BevsM3 BevsM3 is offline
Car: 2010 535i m sport wagon
Default 05-01-2017, 10:54 AM
Originally Posted by Maximum996
Well after the transmission adapted d mode is definetly what this car should of came with, quik firm seamless shifts...s mode holds gears longer and my slip from third to fourth is gone....i spoke with rbttuning and the downshifts i spoke of is actually because of the kickdown delete (which i personally do not like and have the option in mhd anyway)
Cool, so with the kickdown delete does it stay in 3rd?? (using previous example)
Maximum996's Avatar
Maximum996 Maximum996 is offline
Car: 08 535xi
Default 05-01-2017, 03:05 PM
It will downshift like it supposed to, more quiker and less slippage/luxury in d mode...in s mode will hold gears longer...it just will not downshift abruptly from say fourth to second, it will go through third quickly to get to second, this is intentional in the flash not a bug..i have a video from third when im cruising and floor it it will downshift momentarily to second to get to first, im hoping this can be a user adjustable option to enable disable kickdown delete or maybe just have kickdown delete on m mode. I have a video of what i speak about but could not upload here
I have 2 videos up on youtube https://www.youtube.com/channel/UCOp...ZAY6qEi24WTIJQ
08 535Xi - jb4 iso w/mhd flash, Bms dci, AR ********* DP, er cp with forge dv, second *** delete, muffler delete, xhp trans flash, ets fmic, bms oil tstat bypass.
BevsM3's Avatar
Default 05-01-2017, 03:47 PM
Its not going into 2nd gear at all, just displaying that it passed 2nd gear to get to 1st. There is a delay but being in D I would expect that.
RayBan81's Avatar
RayBan81 RayBan81 is offline
Car: 335i E91
Default 05-04-2017, 11:53 AM
All xHP customer are invited to take part in our ongoing "Shift Quality Survey"! We'd like to know from every customer in detail, how satisfied you are with your tune! Therefore we set up this 13 question survey, where you can give us in-depth feedback! It's anonymous and done in just 5 minutes!
Thanks for your time!
xHP Shift Quality Survey
xHP Flashtool: The worlds first Android-based TCU Flashtuning tool!
More Infos on Youtube -> http://*******/2hfYJT8
xHP on Facebook: https://www.facebook.com/xhpflashtool/
Boost'n e92's Avatar
Boost'n e92 Boost'n e92 is offline
Car: 2007 335i e92
Default issue trying to flash - 05-04-2017, 01:52 PM
So I was attempting to do the back up and got message coding missing. Please recode your TCU properly before continuing, I have Alpina already, jb4 and mhd bef, what do I need to do to resolve this, already paid for a license, saw on website one customer had Alpina but it wasn't installed correctly, is that my issue, I have had alpina since I owned the car, my friend prior is the one who had someone flash the alpina.
2007 335i e92 space grey, a/t, fbo, mfactory lsd and boost addictions diff lock down, bmw pe mod, xHP stage 3, mmp stage 3, inlets and outlets and eos pi, custom tuned by pure evil estimated 620whp on e50 23psi. Current 1/4 mi 11.9 @116 on stock turbos.
Suspension: Koni yellows eibach lowering springs
Wheels: iforged Daytona 19x9.5f 19x10r
Drop a gear and disappear.
N54QC N54QC is offline
Car: 07 BMW 335i
Default 05-04-2017, 02:08 PM
This is been brought up multiple times in this thread about coding being missing. This is Clemens response and it may help you.
"As mojo already suggested, you're likely getting a "Coding missing. Please recode your TCU properly before continuing." message.
The solution is exactly what the app says:
http://www.e90post.com/forums/showpo...&postcount=478
Hopefully that helps as you will need to finish the coding before you can backup and upload flash.
Car: 2007 335i e92
Default 05-04-2017, 02:12 PM
http://www.e90post.com/forums/showpo...&postcount=478 "
Link didn't work
Car: 07 BMW 335i
Default 05-04-2017, 02:18 PM
Link didn't work
Yeah, that's weird. Well the link is on page 11 of this thread, post #257. That one works fine.
Car: 2007 335i e92
Default 05-04-2017, 02:24 PM
This one? http://www.e90post.com/forums/showth...&highlight=xHP
Car: 07 BMW 335i
Default 05-04-2017, 02:48 PM
No, this one. This one actually works.
Car: 2007 335i e92
Exclamation 05-04-2017, 04:16 PM
I am no coder, or computer savy. Hopefully xHP finds a easier way around this, it's upseting.
Car: 07 BMW 335i
Default 05-04-2017, 04:44 PM
There are some guys on here that know how to code and can do it remotely. I would just start a thread in the support section. Title it something along the lines of someone who can finish coding your TCU.
Default 05-06-2017, 07:00 AM
ACHTUNG!!! Preliminary verdict.
I loaded the xHP Stage 3 flash yesterday on my black RWD sedan with RBs.
The first thing I noticed is that I now have gear selection showing in my dash, just like M5. Previously it only showed Sport mode, but now I have it for all modes. This is really cool and allows me to see how the transmission is working. Always high on my wish list.
In normal D mode the car is much more sensitive to throttle input and will jump down to 3 from 6 instantly on suburban roads (ie idling along at 40 mph.) It then shifts higher and quicker than before.
I have a dedicated Sport button, and in that mode the car is similar to D, just more responsive and quicker to look for lower gears w higher rpms.
Then I have the D/S mode that we all have, and that's the fun option now. It's like M3 performance where the car is really on its toes and looking to downshift and lock in at even less pedal input.
I still haven't gotten on the highway as we have had torrential rains and I want to live a bit longer. But will amend this post if anything seems worth mentioning.
I have an LSD in the rear and now need to kill TCS whenever I light up the drive train. Else its major slipping even with 9" 275/35/18 Michelin PSSs.
Props to the folks at xHP. Especially for including e60 in this release.
We have never had anything to improve the transmission, and this is a HUGE improvement.
n5418102's Avatar
n5418102 n5418102 is offline
Car: 2008 BMW 535xi
Default 05-09-2017, 10:19 PM
i have a 2008 bmw 535xi and when i connect too the app it gives me 2 options.
#1 limousine
#2 touring
wich one should i select?
anyone here can shine some light?
Default 05-10-2017, 07:09 AM
Limousine if you have a sedan. Touring is e61.
Suggest you run an update of xHP. It should then identify the car via Vin when connected to car.
Nyteryder's Avatar
Nyteryder Nyteryder is offline
Car: 2008 535i
Default 05-10-2017, 03:56 PM
I plan on adding the stage 3 on Friday. Review will follow
E60 2008 535i/ mmp stage 3 turbos/ mmp inlets and outlet/ xhp stage 3 you flash/bms dual nozzle meth kit/vrsf 7" fmic/ vrsf d0wn pip3s/ bms dci/ er cp/ full custom exhaust/ fuel-it stage 2/ mhd flasher/ rb pvc/ bms occ/ bc coilovers/ niche Milan 134 8.5/10.5 / nitto 555g2 285/30/20f 245/35/20r mt et street radials 275/40/17
torn08 torn08 is offline
Car: 08 e93 335i
Default 05-10-2017, 04:59 PM
I'm liking 2.2 even better
08 e93 335i - JB4 w/Trebila tune, alpina trans flash, bms dci, vrsf cp, tial bov, vrsf dp, vrsf 7 fmic, bms occ, fuel it stage 2, N20 TMAP, vtt inlets, st coilovers
Running E50ish
RayBan81's Avatar
Car: 335i E91
Default 05-11-2017, 03:43 AM
New 535i Stage 3 files are uploaded!
- Reworked, more intense Throttle Blips in M Mode
- Quicker Downshifts in M Mode overall
- Reworked 1->2 and 2->3 WOT Upshift in M Mode
- Slightly Quicker Upshifts overall in M mode
- Smoothed out 2->3 Upshift in D Mode under light loads
- Raised Torque Limit to 1000 Nm when Brake Boosting
Car: 2007 BMW E90 335i
Default 05-11-2017, 10:59 AM
Tried the latest Stage 3 for E90...
D mode: WAY too aggressive. 2500 RPM upshifts is ridiculous for an "economy" mode. Upshifts shouldn't be neck breaking either, 2-3 is the worst. Downshifts are nice. City fuel economy has dropped around 6 mpg.
M mode: Downshift rev matching is excessively aggressive to the point that it's clunky and sloppy under 3000 RPM. It seems to be revving while the clutches are still engaged. Upshifts are decent, nearly identical to Alpina.
Why can't we just get a stock D mode? The engineers at BMW are the experts, don't fix what isn't broken... You need to allow the user to mix and match D and M/S modes, and implement user options for rev match aggressiveness among other things. Alpina M with stock D, that's what we've been wanting for the past 8 years...
Pretty disappointed with my purchase. Will be flashing back to Alpina then looking into custom maps.
2013 135is DCT Carbon Black
RayBan81's Avatar
Car: 335i E91
Default 05-11-2017, 12:16 PM
You are on the wrong version. Flash V1.2 or V1.1.
No idea what the issue is. It's all there.
V2.2 is made for Single Turbos which lag torque down low.
Default 05-11-2017, 01:01 PM
I will try. Does 1.1/1.2 have the same rev matching as 2.2 in M-mode? If so I'll pass, it's definitely going to shorten the life of the transmission.
Still not sure why we can't get a stock D mode. There is nothing wrong with it.
RayBan81's Avatar
Car: 335i E91
Default 05-11-2017, 01:22 PM
Just read the "Changelog" in the Stage 3 map. It describes whats changed in each version. The blips will smooth out over time. As the blips get faster, the timing window where they are smooth gets narrower. Depending on your transmission's condition and your current adaption values this may take some time.
There are multiple versions included in Stage 3, so that people can pick what they like most. Theres no "One for all" in transmission setups.
Reading your lines I suggest to use V1.1.
Default 05-13-2017, 07:37 AM
Yup, 1.1 is much better! Well done!
I would consider renaming your map versions. The tendency is for users to go with the latest version to get the latest updates, but your veeaions are meant for different applications.
Car: 08 e93 335i
Default 05-13-2017, 08:07 AM
Agreed.
Running E50ish
BevsM3's Avatar
Default 05-13-2017, 01:09 PM
So do i just re-write the file? Does it have a new name or version to choose?
