Granite66 Granite66 is offline
Car: Bmw 135
Default DCT flash - 11-27-2018, 01:10 AM
I am currently experiencing clutch slip at 28psi with Precision 6266 turbo on my e series 135. Iíve got Dodson clutches but I think I need a gearbox flash more than a clutch upgrade. Iíve heard xhp will be releasing a flash for the 8speed soon. Does anyone have any idea if they will be releasing a dct flash?
Iíve logged a 100-200 time of 5.7sec on 26psi. Not sure how to upload a pic of the time. It says file too big
houtan houtan is offline
Default 11-27-2018, 04:19 PM
Which dodson clutches are you using? Do you have the M4 flywheel? Also, what tune?
keyap keyap is offline
Car: N55 135i
Default 11-28-2018, 02:55 PM
This is worth a read:
https://www.n54tech.com/forums/showthread.php?t=40495
Don't think there's much else currently out there other than BMW alternatives and from my experience, there's little to no gain using these. The only way is to manipulate plate pressure is by changing the relevant parameters in a BEF.
[SIZE="2"]UK 2011 - E82- 135i - N55 - DCT
[B]
