Juan_BIGBOOST_TURBO's Avatar
Default BigBoost Stage 3 turbo results - 05-23-2018, 10:51 AM
Dyno results:
1. Juan's 2016 M235i:
Name:  BigBoost M235i.jpg
Mods:
BigBoost stage 3.3
Fuel-it Port Injection with 550 cc injectors
Fuel-it stage 3 low pressure fuel pump
JB4
BMS intake
Evolution Racewerks chargepipe
Fuel: E30
Boost: 18 PSI 560 WHP 20 PSI 584 WHP
Graphs:
2. Robert's 2012 135i
Name:  ROBERT's 135i Engine.jpg
Mods:
BigBoost Stage 3.3
Fuel-It Port Injection
Billet Motorsport Stage 2 LPFP
Back-End Flash
Phoenix Racing Intercooler
Burger Tuning Intake
JB4
Fuel: VP MS109
BOOST:20 psi 600 WHP 25-26 psi 631 WHP
Graphs:
Name:  BMW Flash tune 25psi.jpg
Name:  BMW wIth Flash tune.jpg
3. Garcia's 2012 135i
Mods:
BigBoost stage 3.2
Meth Injection
BMS Intake
JB4
Upgraded LPFP
Custom Free-Flow exhaust
Fuel: Pump 91
Boost: 19 psi
Graph:
Name:  135i Garcia.jpg
4. Cameron’s 335ix
Name:  Cameron 335ix.JPG
Mods:
BigBoost Stage 3.2 turbo
Port Injection
Stage 2 LPFP
TPG Tuning custom tune
Fuel: Pump 93
Graph:
5. Felipe's M135i F20
Mods:
BigBoost Stage 3.3
Stage 2 LPFP
BootMod3 Custom Tune
ER Chargepipe
BMS Intake
Fuel: Pump 91
Graph:
¼ Mile:
1. Aakash’s M235i
Mods:
BigBoost stage 3.3
BootMod3 custom tune by PTF
ER Chargepipe
Fuel: Pump 93
Boost: 17 PSI
Slip:
2. Juan’s M235i
Name:  Juan M235i 1.jpg
Mods:
BigBoost stage 3.3
JB4
BM3
BMS intake
Fuel: Pump 93
Boost: 17 psi
Slip:
webpage: bigboostusa.com
BigBoost's car: BMW M240i
Stage 3.4 turbo
4.8 100-200
10.85 @ 135 1/4 mile
Daily Driver: BMW M235i
BBT stage 3.3 turbo
Default 05-23-2018, 11:01 AM
These are all very very impressive numbers! Can you include what size mm turbo most are running?
Default 05-23-2018, 11:06 AM
All stage 3.2s are 5959s
All Stage 3.3s are 6159s
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
houtan houtan is offline
Default 05-24-2018, 02:36 PM
those are impressive results. are there any logs you can share of the pulls? Also, for the 135i's, are any of them DCT?
Default 05-24-2018, 07:19 PM
The Gray one is DCT. Also Ricardo Saca’s car @135ilove is DCT as well with SSP.
Let me look for some logs for local cars.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
keyap keyap is offline
Car: N55 135i
Default 05-25-2018, 01:22 AM
+1 on the logs
[B]
Default 05-25-2018, 08:33 AM
This is the most recent log on the white 135i 6MT on the dyno.
Name:  MAP 6 WH 135i.png
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Car: N55 135i
Default 05-28-2018, 05:32 AM
Hey Juan, thanks for the log.
Would one of these work on a RHD 2011 N55 E82?
Also, have you noticed any issues at tip in and when boost is pushed nearer the mid 20psi range with the DCT equipped vehicles? Am specifically thinking false knock/misfires.
[B]
Car: 2011 N55 135DCT
Default 05-28-2018, 06:36 AM
Is it just me or that log the afrs are really lean and also high timming?
Default 05-28-2018, 07:12 AM
Hey,
Yes sometimes we see false misfire in CYL 6 and well it cuts injection on that cylinder, however with the M4 flywheel these are gone. Unfortunately the Echassis RHD is extremely tight and we haven't managed to design something that will clear the steering column. We've had luck on RHD F-chassis but not e-chassis RHD yet.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default 05-28-2018, 07:15 AM
I think it's not that bad considering we were running full Race Fuel on it. Low 13s is what we usually run, going richer will tend to produce misfires.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default 05-28-2018, 07:55 AM
Ok awsome Jaun. Was just asking. Im normaly told 12 afrs.
Default 05-28-2018, 09:26 AM
On this direct injection engine it's good to run 13.1-13.3, it will produce good power and torque, it's safe so you should tune around 12.9-13.2 and you should be making even more power out of that GTX3576R!
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default 05-28-2018, 09:57 AM
Thank you Juan. I will do that. Will that AFR be good for 28psi
Car: N55 135i
Default 05-28-2018, 02:23 PM
Jeez Jacques - 28psi on a single with, I'm assuming, the usual N55 restriction removed.
That must equal
Yep, position of that steering column is an absolute *****. The 'yet' bit of your response makes me think there may still be hope otherwise it look like RHDs may be top only. Unless a smaller single could be squeezed in but that sort of defeats the purpose!
[B]
DB90 DB90 is offline
Car: M135i
Default 05-28-2018, 03:38 PM
Originally Posted by Juan_BIGBOOST_TURBO
Hey,
Hi Juan just to clarify, your kits now work on all f-series RHD rear drive cars?
M135i 8AT / JB4 + EWG Harness / N20 TMAP / VRSF 5" HD FMIC / Fuel-It TBI / Fuel-It STG2 LPFP / Pure High Flow Inlet / FTP Charge & Boost ***** / Richter ***** / Backbox delete / E50 Fuel / ngk 5992s / BBS CH-R's / KW V3 Coilovers / M4 LCA's / GP Front Splitter & Side Blades.
100-200kph: 7.8s
1/4 mile: 11.9s @ 120mph
Default 05-29-2018, 02:31 AM
Keyap. Im runninh 25 psi at the moment. Busy with Custom e60 BEF. Then go to 28psi
Weehe Weehe is offline
Default 05-29-2018, 05:54 AM
You said it was 93 in the same post. Race gas or not 13+afr is a ticking time bomb. Low 12s for pump, high 12s for E85
Default 05-29-2018, 09:06 AM
Mods:
BigBoost Stage 3.3
Back-End Flash
JB4
Fuel: VP MS109
Graphs:
This is what I said in the first post, VP MS109.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default 05-29-2018, 09:21 AM
You were asked for a log and then you posted this with the log:
This is the most recent log on 93 octane on the white 135i 6MT on the dyno.
Attachment 74936
It is way too lean.
Default 05-29-2018, 11:56 AM
Hey, yes, but it's a custom order kit so will take 5-6 weeks to ship.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default 05-29-2018, 11:59 AM
It is way too lean.
Yep, my mistake this was last time we tuned it which was one Race gas, not 93. Well the car has been running like this since Dec. 2016 and engine is just fine, so I don't think its bad.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 05-29-2018, 12:42 PM
3.3!!!
niceast
Guest
Posts: n/a
Default 05-30-2018, 11:09 PM
I like the numbers from Robert's 135i.
Default 05-31-2018, 07:07 AM
I run 12.4 afr and now have 11.9 afrs on my GTX3576R kit
