(#1001)
Snkrspot Snkrspot is offline
Car: B9.5 S5
Default 10-07-2021, 10:23 AM
Finally getting around to installing my JB4 into my B9.5 S5 today. I intend on keeping the car stock (other than the JB4).
With that, curious if I should bother installing the BCM plug? Any benefits in doing so? Or risks if not? Also, I assume the ground wire still needs to be connected regardless of the BCM install?
Thanks.
Default 10-07-2021, 12:09 PM
Thanks.
Some customers report faster spool so wont hurt to fit it. Terry has covered the plugging in of it in this video: https://youtu.be/bNP1cy-QOi8
2021 VW Golf 8 R
Car: B9.5 S5
Default 10-07-2021, 02:10 PM
Thanks. Fitting it was a breeze. Overall the entire install was simple and straightforward (outside of running the OBD through the firewall).
One more question. Which Map would be the best for my application (stock B9.5 S5 Sportback w/91 Octane).
Thanks again.
Default 10-07-2021, 03:35 PM
Thanks again.
Map 2 is the recommended map for 91.
2021 VW Golf 8 R
perc9k perc9k is offline
Car: 2020 Audi S4
Default 10-13-2021, 11:45 PM
Running map 5 on S4 B9.5 and only seeing 4.0s to 60.
I run 5 gallons e85
Mid Muffler and resonator removed.
Los Angeles
What are good conservative map 6 settings that I can use without logging? (Haven't been able to log yet since I am using laptop.
Default 10-14-2021, 05:17 PM
I run 5 gallons e85
Los Angeles
You could possibly be spinning on the launch and loosing time. Log it and email logs to me at george@burgertuning.com and I can see if it can be improved.
2021 VW Golf 8 R
Bagy Bagy is offline
Car: Seat Leon Cupra 300
Default 10-16-2021, 12:42 AM
Hi everyone
I am running map5 (Audi RS5) and. noticed that after a launch control the shifting between first and second gear is not so fast as it should be. Like some kind of torque reducing is happening
Should i reduce the boost in the first gear? Or this should not happen
0-61mph takes 3,46 sek (0-100kmh). But i think it could go faster. Thanks in advance
Default 10-17-2021, 08:32 AM
Originally Posted by Bagy
Hi everyone
The time is pretty good relative to traction. It could be catching some wheelspin and reducing first might help. Try make boost cut 1st value 2 and see if it improves the shift. The value entered is how many psi it will cut in the gear.
2021 VW Golf 8 R
