KPDcompany's Avatar
KPDcompany KPDcompany is offline
Car: E90 2008 335i
Default *NEW Product* DIY LPFP Bucketless Bracket System - 04-20-2018, 04:55 AM
A Little background. I'm an Engineer by trade, and have my own design & prototyping company. I've been building/Modifying cars for 10 years, although this platform is fairly new to me. I saw a need for lower priced bucketless lpfp solution. I have started to create my own Stage 1 & Stage 2(optional) bracket system. This will initially be released as a DIY Kit. It will come with the Bracket only, with the below being options you can choose while checking out from BMP(Black Market Parts) once released.
-Stage 1 Main Bracket
-BMP Fuel Pump to Factory Fuel Line Connection(option)
-Wiring Connector for pluging into stock connector(option)
-All bolts(Included)
Stage 2
-Stage 2 Bracket Addition
-BMP "Y" Hose for running 2 Pumps(option)
-All Bolts(Included)
The bracket by itself will be UNDER $100 testing is underway and I'm happy to report there have been zero issues! I Made this for myself, and for others like me who would rather buy their own fuel pump, and just needed a bracket and a couple odds and ends. This was not designed to directly compete with any other suppliers who offer fuel pump solutions, just to fill a market gap for a lower priced DIY Bucketless setup. I am also open to anyone's ideas, concerns, or anything else they would like to see in the kits that I did not list. Please see below pictures, let me know what you think, and I will keep this post updated with all progress.
These are available from the following link
http://www.bm-parts.com/index.php?ro...search=bracket
-Travis
Email - contact@kpdcompany.com
2008 335i Sedan M-Sport - Auto / M3 Body Conversion / JB4 E85 BEF / BMS DCI / BMS OCC / VRSF CP-HKS SSQV / Forge FMIC / KPD Bucketless LPFP / Muffler Delete / Poly Rear Bushings / M3 F&R Arms / StopTech SS Brake Lines
blaster3500 blaster3500 is offline
Car: 2007 335i
Default 04-20-2018, 06:01 AM
I would he interested. Is the bracket going to be aluminum?
07 E90 335i 6mt
KPDcompany's Avatar
Car: E90 2008 335i
Default 04-20-2018, 06:25 AM
It is made of a Carbon Fiber Reinforced Nylon. This material has already passed all heat & Chemical tests. 100% E85 & Gasoline Safe(nylon is the same material used for the fuel pump lines) resists vibration better than metals, weighs far less, and is just as strong as aluminum. For reference this material is very similar in make up of the same composites used for our radiator end tanks, and other high load/temp composite parts. Comes with a 1 Year warranty that covers everything. Any manufacturing defects will be warrantied for as long as the original purchaser owns the car/pump bracket.
KPDcompany's Avatar
Car: E90 2008 335i
Default 04-20-2018, 09:20 AM
Why was this moved? This is not meant to be a for sale ad. This is supposed to be a discussion of what people think, and to track the progress of this. There are a bunch of other threads that do the same thing, posting about new products in an informative matter. For instance, the following threads do the same thing I am doing? I'm just a little confused Thanks!
BMS PCV
China Inlets
Custom tuning(BEF)
Vader Tablet CLip
Dragy Box
Frankenturbo
matthewo matthewo is offline
Default 04-20-2018, 01:11 PM
make it fit a DW400 - 46mm body
KPDcompany's Avatar
Car: E90 2008 335i
Default 04-20-2018, 01:21 PM
I decided against that due to the extra strain that one single DW400 puts on the EKP, let alone when there are 2 wired up. BUT if there is enough demand then I will gladly make a DW version. If you would like I can make you one if you are absolutely stuck on the DW400. But I assure you it's not nearly as much of a flow difference as most believe. Let me know if you would like one.
PrzeChuj PrzeChuj is offline
Car: 08 335i
Default 04-20-2018, 04:10 PM
Here bmp I bought. Wired second pump to a rely and Hobbs switch in the trunk . Second pump turns on around 13psi
e92 MT 08
Single T
FBO
Dual 450 lpfp
BEF
MeTH!!!!!
E85 100/
Car: 08 335i
Default 04-20-2018, 04:11 PM
Just the parts
e92 MT 08
Single T
FBO
Dual 450 lpfp
BEF
MeTH!!!!!
E85 100/
KPDcompany's Avatar
Car: E90 2008 335i
Default 04-20-2018, 05:55 PM
Originally Posted by PrzeChuj
Just the parts
Yes, My bracket will use the BMP hose, and fittings. My bracket will be cheaper & my bracket kit will also be available from BMP's website to buy fairly soon. My design is differnt, not saying its better, just saying that some people may prefer to pay $50-70 less than any other bracket on the market. You can buy my bracket as the stage 2, then buy the add on module for the second pump and it will come with the hoses and fittings. Even after buying the stage 3 add on bracket, it will still be cheaper than any other 2 pump offering.
KPDcompany's Avatar
Car: E90 2008 335i
Default 04-21-2018, 08:09 PM
Also, make sure you flip that pump assembly around 180. The Float should be pointing toward the front of the car, and the BMP logo towards the rear of the car.
BeastMode335i's Avatar
BeastMode335i BeastMode335i is offline
Car: 08 E92 335i
Default 04-23-2018, 11:10 AM
Looks nice man, good luck..!
MR F30 335i - MSport - Stock AF
KPDcompany's Avatar
Car: E90 2008 335i
Default 04-23-2018, 11:53 AM
Thank you!, I appreciate it.
syn909 syn909 is offline
Car: '07 335i
Default 04-23-2018, 10:57 PM
This is perfect for my needs, I just picked up a 335i and want to install the Walboro for e85 compatibility. Sign me up!
NoGuru's Avatar
NoGuru NoGuru is offline
Car: 2011 335is
Default 04-24-2018, 11:51 AM
I was going to upgrade the lpfp very soon so I would be willing to test a mount and make a DIY pump for a Walboro 450.
KPDcompany's Avatar
Car: E90 2008 335i
Default 04-24-2018, 12:32 PM
Sounds good guys, thanks for the interest. PM for info if you are interested in getting a bracket before they are available from BMP.
NoGuru's Avatar
Car: 2011 335is
Default 05-07-2018, 06:08 AM
I received my bracket and a nice pen with it. The part is very light weight but seems durable. It is printed in a high resolution but I am not sure what the materiel is. Great quality of the print.
The install is pretty straight forward for DIY guys. The only parts that held me up a little is pushing in the hose release buttons on two hoses and pulling while trying to hold the bucket up in the tank.
I cut the connector off my old pump and soldered and shrink wrapped the connections.
Hooked it up and was up and run in about an hour in total.
KPDcompany's Avatar
Car: E90 2008 335i
Default 05-07-2018, 06:32 AM
Glad you like it and it went well! The material is a Carbon Fiber Nylon Composite. VERY Strong. Glad to hear it went well!
orteeze orteeze is offline
Car: 08' 335i
Default 05-07-2018, 08:41 AM
KPDcompany, can I get a dual walbro 450?
E90 LCI M Sport
KPDcompany's Avatar
Car: E90 2008 335i
Default 05-07-2018, 08:49 AM
I'm Printing yours out this week. Test units have went out, yours will be out shortly!
Car: 335i, 2009
Default 05-07-2018, 10:29 AM
Wish I knew about this sooner, I replaced my bucket a few months back.
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
KPDcompany's Avatar
Car: E90 2008 335i
Default 05-07-2018, 10:31 AM
With a stock one? Hey it's never too late its easy and quick. Also these will be up on BMP's website fairly soon!
EDIT- Just saw your signature where you have a stage 2.
Car: 335i, 2009
Default 05-07-2018, 10:39 AM
a stage 2 fuelit bucket, good replacement, but expensive
BMS Stage 1
KPDcompany's Avatar
Car: E90 2008 335i
Default 05-07-2018, 10:43 AM
Ya it is nice, but you are right, that was my main reason for creating this, make something available to people who didn't care to have a bucket, DIY'ers or budget minded folks.
Also, anyone know why the "strike-through" doesn't work on here like the below?
[s] test [/s] ?
Aus335iguy Aus335iguy is offline
Car: 2009 335i dct msport
Default 06-09-2018, 05:23 PM
Sent you an email need one shipped to Aus fairly sharply if you can ?
KPDcompany's Avatar
Car: E90 2008 335i
Default 06-10-2018, 07:34 AM
I emailed you back this morning, thanks for the interest.
