Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default RB Cold Side Silcone Chargepipe 335D relocation kit gauging interest>> - 08-02-2015, 01:04 PM
All,
We have decided to make a cold side full silicone kit for those looking to use the 335D coolant reservoir for those applications looking to put air filters on the passenger side of the vehicle (ie. ST's, TFT/MMP style inlets, etc). We would like to gauge some interest in this type of kit in order to produce it.
Keep in mind the kit may become more inclusive (and thus costly) as time goes on, but for now all that is included is the following items:
1) Throttle Body CNC adapter with TMAP provision (T-Bolt clamp) PLEASE note this will be anodized black.
2) Throttle body to BOV adapter Silicone Elbow (T-Bolt clamp)
3) BOV adapter (provisioned for Tial BOV ONLY at this time) PLEASE note this is not complete in the pictures but will be upon shipment (2 Piece Fully CNC'd and welded) and will also be anodized black.
4) BOV adapter to IC cold side Silicone formed hose (2 T-bolt clamps both ends)
This is all the into kit will come with at this time for the price of $299 for 10 slots.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
THIS WILL NOT WORK WITH OEM ROUTED INLETS WITH AIR FILTERS ON THE DRIVERS SIDE!! And if you are not sure if you need this, then it is most probable that you do not.
Thanks,
Rob
Car: 09 E92 335i
Default 08-02-2015, 05:32 PM
This is great, since the guys that uses PI or TBI need a more flexible charge pipe as well.
Stalker
Car: 335I
Default 08-02-2015, 05:45 PM
Agree. Certainly allows compliance with the PI spacer as well.
Car: 09 E92 335i
Default 08-02-2015, 06:08 PM
Oh man, wish you made this two months ago. I spent more than 5 hours trying to install the CPE charge pipe with the Fuel-it TBI kit back in May...
Btw, where does the DV/BOV port go on this?
Stalker
Car: 335I
Default 08-02-2015, 06:20 PM
See post #1 Point #3.
Cynical Cynical is offline
Default 08-03-2015, 06:48 AM
Wont work on 335is or anyone with ppk kit. The angle is wrong and will be in the way of the added coolant lines
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 08-03-2015, 06:55 AM
Not a fan of silicone for ***** that see higher boost pressure. They expand under boost, wire reinforced or not, which dampens throttle response and hurts spool. No thanks.
EMC's Avatar
EMC EMC is offline
Car: 335d
Default 08-03-2015, 11:25 AM
Where do people come up with this stuff? You act like it's a balloon that swells up to double the volume.
Have you ever pressure tested a multi-layer reinforced silicone hose like this to see what it really does? If you said you could tell a difference in boost response between this and an aluminum charge pipe, you would be lying.
2008 535xi wagon
Car: 2010 135i 6MT
Default 08-03-2015, 12:28 PM
I drove a silicone "cold-side" IC pipe vs. an SS hard pipe back to back on my Evo X, running 28psi, and yes it was a noticeable difference. Boost plot on the dyno was also noticeably different. And you can physically see the silicone pipe expand when under load / higher boost on the dyno.
What have you done?
EMC's Avatar
EMC EMC is offline
Car: 335d
Default 08-03-2015, 12:48 PM
What have you done?
I call BS on a boost plot being different because this N54 charge pipe hose being made of silicone. Common sense and real world testing would show there's no difference so long as the dimensions are kept the same. The air flowing through the hoses doesn't care what material it's made from.
2008 535xi wagon
Stalker
Car: 335I
Default 08-03-2015, 12:53 PM
We probably should have been a little more clear on the boost response issue. For those who measure their boost response down to the nano second, you may see some delay by using this setup. BTW we are not using wire reinforcement as that is only for inlet/vacuum applications and will have no real affect on pressure side.
Rob
3000GT MR's Avatar
3000GT MR 3000GT MR is offline
Car: 09' 335i
Default 08-03-2015, 02:32 PM
if it is going to be a single full 3" from IC to TB i may be interested.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust
335i 2009 e90 665RWHP VFF900 ST RIP .
Stalker
Car: 335I
Default 08-03-2015, 02:37 PM
It is provisioned to be tailored as such (3.25" at TB tapering to 3" at BOV adapter, 3" at BOV adapter tapering to 2.5" to mate to most IC's that are 2.5". The problem with 3" down on the lower side is that 2.5" fits just barely… lol. The piece of silicone from the BOV to the IC will eventually be made for 3", but it will likely be not for the typically enthusiast as some other "fitment mods" will likely be necessary.
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 08-04-2015, 12:09 AM
What have you done?
Boom!
^ aka keyboard expert! Cos air doesn't expand and contract right?
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 08-04-2015, 10:27 AM
I'm sure it's functional. Just kind of ugly, lol.
335is DCT
Stalker
Car: 335I
Default 08-04-2015, 11:30 AM
Once anodized, will be very stock as can be looking, which is of our personal preference.
BostonBeemah's Avatar
Car: AW 135i
Default 08-04-2015, 04:11 PM
I would also be interested in this. I think people wouldn't care about the "extensive modifications" ie cutting the fan shroud a little more than it is already cut.
Are you going to be selling the chargepipe separate either way?
RIP 2008 AW/BL 135i
_ink's Avatar
Car: 335i DCT
Default 08-04-2015, 11:31 PM
Would rather the hot side charge pipe Rob. In aluminium.
skyguy's Avatar
skyguy skyguy is offline
Default 11-17-2015, 04:38 PM
Wait, I missed this thread. Is it too late to get in on this?
07 e90 w/ 4l80e & Motiv750
Stalker
Car: 335I
Default 11-17-2015, 05:06 PM
I can order them but unfortunately only in quantities. Had some sweet adapters CNC'd for this and everything, no one seemed to like any of it though. If we can get some interest, I'd get some on order.
skyguy's Avatar
Default 11-18-2015, 04:20 AM
I'm in, if anybody signs up and these get made. They're exactly what I'm looking for as long as it's one continuous piece with a factory style adapter. Only a matter of time til somebody makes these.
rhm135's Avatar
rhm135 rhm135 is offline
Tech
Car: 335is
Default 01-25-2016, 10:05 AM
Did these ever get produced? I need this for my inlets!
2012 335is DCT - JB4 - Fuel-it! - MHD - SSP - DocRace
Stalker
Car: 335I
Default 01-25-2016, 10:27 AM
Only made the one-off at this time. Could put into production at any point, but was hesitant by the apparent lack of interest.
These are designed so that we can also make a full 3" up to the BOV adapter too (which increases to 3.25" at the TB), but of course they will not fit quite as nicely as the standard and current 2.5" towards the IC. They'd be really nice for production, after welding/anodizing/etc. Initial BOV adapter would be Tial.
Rob
suspenceful's Avatar
Car: 2008 BSM 135i
Default 01-25-2016, 12:11 PM
Call me stupid, but what is this for? Just to be able to relocate the coolant tank?
I'm about to pull the trigger on some Precision Raceworks inlets (passenger side), and am curious what advantages something like this would bring.
rhm135's Avatar
Tech
Car: 335is
Default 01-25-2016, 12:13 PM
Would there be a meth bung? I am currently using a Hobbs switch for my TBI.
