Bobdudeman1988's Avatar
Bobdudeman1988 Bobdudeman1988 is offline
Car: 07 E90 335i
Default 03-03-2015, 07:23 AM
holy crap. what cars does that fit?
I AM BOB!
vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 03-03-2015, 07:45 AM
Please rephrase your question.
4doorbmwpower's Avatar
4doorbmwpower 4doorbmwpower is offline
Default 03-03-2015, 09:54 AM
does the 650i cover fit? like can i just buy one and pop her on my 09/06 build date 335i? I would totally do that as a cheap alternative. Does it increase fluid capacity at all?
Coming soon.
vwetish's Avatar
Default 03-03-2015, 09:57 AM
It fits, but it doesn't increase fluid capacity.
Robert's Avatar
Robert Robert is offline
Car: bmw
Default 03-03-2015, 10:56 AM
Originally Posted by 135droptop
Why are so many of you on this forum so negative? And I don't care about you high jacking my post. It just gives me more exposure. There are people out there who can do things others say cant done. Like selling a good bracket for half the cost of inferior others.
If your not interested in purchasing my bracket then move on and make your own thread (as I did).
100% agreed here.
I guess I will be one of the first to R&D this upgrade in couple of weeks (weather depending).
Ready to put my order in
2008 e92/MHD Wedge E85/Alpina TCU /RB Inlets/MMP Outlets/Vrsf DP/Helix FMIC/Forge DV/BMS CP/DCI/Fuel It st2/TBI/TC Kline/Swift SA coils/MF lsd/Hotchkis sway bars/M3 front and rear links/ Diff LDK/AKG Race subf/diff bushings/Megan toe links /TSW18 forged Nurburring/Mich PSS 245/265 /BMW(Brembo)M perf 370mm BBK
135droptop's Avatar
135droptop 135droptop is offline
Default 03-03-2015, 11:01 AM
Originally Posted by Robert
100% agreed here.
You won't be sorry, I have sold many and everyone is thrilled so far.
Car: 07 E90 335i
Default 03-03-2015, 11:36 AM
What differentals does that cover fit, large? Small? Any modification required?
I AM BOB!
vwetish's Avatar
Default 03-03-2015, 11:47 AM
Large, you can find all the info here:
http://www.1addicts.com/forums/showthread.php?t=1057536
vwetish's Avatar
Default 03-03-2015, 12:08 PM
Please, enough with off topic questions. OP has a good product.
Let all concentrate on that. All other discussions belong to another tread!
Car: 07 E90 335i
Default 03-03-2015, 02:35 PM
Im done to the op, it looks fantastic, but, as constructive feedback as a welder myself, if you made a stainless version. Id be all over it just saying. good work
I AM BOB!
Evil///M's Avatar
Evil///M Evil///M is offline
Car: 335i/e36m3
Default 03-10-2015, 10:28 PM
So it just bolts to existing holes in the subframe??
135droptop's Avatar
Default 03-11-2015, 03:31 AM
Yes that's correct. It's a 20 min install.
vwetish's Avatar
Default 03-11-2015, 04:44 AM
Not all subframes have holes from factory. Check yours first.
135droptop's Avatar
Default 03-11-2015, 04:46 AM
Most do, I have never heard of anyone not having the two holes with the brackets I sold. Even if it does not have them (which I bet it does), its an easy drill job.
vwetish's Avatar
Default 03-11-2015, 04:57 AM
I agree, is easy to drill. Here is photo from a subframe that doesn't have the factory holes
135droptop's Avatar
Default 03-11-2015, 04:59 AM
Do you happen to know what year and model that car is?
vwetish's Avatar
Default 03-11-2015, 05:01 AM
yes, I do. 2007 e92 335i
Evil///M's Avatar
Car: 335i/e36m3
Default 03-12-2015, 08:31 PM
2007???? Oh no...
vwetish's Avatar
Default 03-13-2015, 04:48 AM
2007???? Oh no...
don't panic, there is a solution for your car as well.
Evil///M's Avatar
Car: 335i/e36m3
Default 03-13-2015, 10:50 AM
Just looked under my car and there's no holes...
135droptop's Avatar
Default 03-13-2015, 11:10 AM
You can just drill the holes you need, no big deal. Use the bracket after its mounted to the pumpkin as a templet to located them.
Evil///M's Avatar
Car: 335i/e36m3
Default 03-15-2015, 04:54 PM
The holes to the diff didn't line up I had to drill them out more to make them wider. Couldn't drill into the subframe, barely even broke the surface. Once I had it bolted to the diff it still was about half an inch away from the subframe.
I highly suggest you check to make sure you have the holes first before buying, unless you feel like wasting hours trying to drill 2 holes into your subframe lol.
135droptop's Avatar
Default 03-15-2015, 05:28 PM
This is the first time anyone had issues mounting it. The sub frame does not always have the holes in it so, thats just the way that is. The pumpkin holes should have lined up unless something is different with your 135. If you can take some pictures so I can see whats going on I'll try and help. You have an auto or 6 speed, I can't remember everyone's order. PM me your full name so I can look it up in my emails.
135droptop's Avatar
Default 03-15-2015, 05:38 PM
Oh and a 1/2 inch is allot so thats more then a variation from car to car.
135droptop's Avatar
Default 03-15-2015, 05:43 PM
I just looked up your order, it was for a large diff so, it being off 1/2, something much different on your car. I have sold over 25 of these and none have had an issue like this.
