suspenceful's Avatar
Car: 2008 BSM 135i
Default Manual 135i Runs a 10 Second 1/4 Mile Pass @ 136mph! - 06-27-2019, 09:43 AM
I finally made it to the 10 second club! One of four(?) N54-powered vehicles in the 10's with a manual transmission.
Follow me on Instagram: https://instagram.com/jakespence
Subscribe on YouTube: https://youtube.com/jakespence135
Stock motor
Stock transmission
Stock differential
Stock axles
2008 BMW 135i 6-speed Manual
Doc Race single turbo 6266
JB4 map 7 (28psi)
MHD backend flash (Wedge)
Doc Race intake manifold w/ port injection (72lb)
Precision Raceworks stage 3+ LPFP
VRSF 7.5" race intercooler
Custom 3" exhaust
Precision Raceworks ignition coils
NGK 97506 @ 0.022"
Pump E85
2560 DA - Log attached
If you want to watch the whole process and how I eventually ran the 10 sec pass, watch the video below. Otherwise if you just care about the results, slip is below
Gonna work on chopping that 60ft down and improve shifts to knock it down even further.
Dragy slip from the same run:
🚀 My 750HP 135i build: my1series.com
🔧 My budget 335i build: bmw335i.com
📷 Follow me on Instagram: instagram.com/jakespence
🎬 Watch me on YouTube: youtube.com/jakespence135
🌟 Support me on Patreon: patreon.com/jake_spence
🏁 Shop BMW merchandise: bimmerstreet.com
Default 06-27-2019, 10:33 AM
Awesome man! That's not an easy feat. Congrats on the numbers, truly impressive.
Prototype007 Prototype007 is offline
Car: 2009 335i
Default 06-27-2019, 10:57 AM
Very nice and beautiful ride!
2009 335i Automatic Coupe.
Car: 2008 BSM 135i
Default 06-27-2019, 11:20 AM
Thanks Payam!
Thank you!
DamnDatsun's Avatar
DamnDatsun DamnDatsun is offline
Car: 2010 135i msport
Default 06-27-2019, 11:22 AM
Did you use boost by gear in the jb4? Love your videos.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 06-27-2019, 12:12 PM
Paging Sticky
Car: 2008 BSM 135i
Default 06-27-2019, 01:27 PM
Nope, but I will note that this turbo doesn't hit full boost until 3rd gear. Targeting 28psi, it was only able to hit 22psi in 1st gear and 24psi in 2nd gear. Thanks for watching!
deltalima0's Avatar
deltalima0 deltalima0 is offline
Car: 07 BMW 335
Default 06-28-2019, 05:31 AM
Congrats! Welcome to the 10 second club. I am really surprised you are on stock axles now that is a feat, I would have figured the axles would have gone by now.
Congrats again I know the trek to the 10s are not easy and people just think throw upgraded turbos in and have FBO mods and your there but they forget the fine details of fueling, Drag radials, upgraded axles in my case, dialing in tuning and the constant upkeep that a car pumping 700 plus horses require to keep the gremlins away.
Keep it up and I love your channel.
2011 335is DCT
Pure Stage 2 Hi-Flo Turbos | PSP outlets | RB Inlets | Wagner Evo 2 intercooler | Wagner Dpipes's | JB4 G5/MHD| Fuel-it stg 2 bucketless LPFP | ER Charge Pipe with Tial BOV | JB4 G5/MHD | BMS DCI's
RIP 2007 E90 335i
Doc Race 6266 Single Turbo | TFT Charge Pipe | JB4 G5/MHD | FuelIt stg 3 LPFP | Cpe/BMS PI | 100% E85 | DSS Axles | Cpe FMIC | Tial BOV
N54 World Record ET: 10.721 | Best MPH 130.92
Car: 2008 BSM 135i
Default 06-28-2019, 08:54 AM
Thanks man! I've already sheared two axles, but just replaced them with $60 junkyard OEM units.
I appreciate the support
codesx codesx is offline
Default 06-28-2019, 09:25 AM
Epic!
Side topic;
Your Docrace intake manifold is of an interesting design.
Did they provide any documentation on air flow, pressure or vacuum at the different points?
2008 335i Convertible, E93, N54, A/T (190,000+ km)
TUNE: JB4 Map 6 | RACE BEF | 94 Octane | @19 PSI
BMS JB4 | BMS WMI @ 60/40 (CM10) | BMS 5" FMIC | BMS OCC | BMS DCI | BMS Cowel Filters
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
NGK 5992 Plugs @ .020
Maintenance:
2018 - A/T Replaced | Plugs | Ign Coils | Walnut Blasting
2019 - VCG | OFHG & O-rings | Alternator w/ Clutch Pulley | Water Pump & T Stat
Car: 2008 BSM 135i
Default 06-28-2019, 10:00 AM
Originally Posted by codesx
Epic!
Side topic;
I'm not too sure, check out their website or look up the production threads on some forums.
Default 06-28-2019, 10:12 AM
This makes me want to get our white 135i MT back to the dragstrip!
Default 06-28-2019, 10:59 AM
She is a crazy beast!
Let Payam know if you are turning up the boost him
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
Maintenance:
Default 06-28-2019, 03:57 PM
Jake this log is with that clutch slippage device?
NA55 NA55 is offline
Default 06-28-2019, 07:37 PM
Good job on the 10 second pass.
What tires and size are you using?
What tire pressure?
Car: 2008 BSM 135i
Default 06-30-2019, 07:06 PM
No - it's not. Why?
What tire pressure?
Thanks! I am running 275/40/17 Mickey Thompson ET Street R tires at 16psi warm.
Default 06-30-2019, 07:21 PM
Does the Xtreme Twin Disc clutch allow enough slip to take advantage of the clutch delay solenoid? I’m using a M-Factory Twin Disc and have thought about the clutch delay, but it seems to be a little too grabby.
Car: 2007 e90 335i
Default 07-01-2019, 01:21 AM
Sick car!!! I watch and love all your you tube videos.
2007 e90 335i
Car: 2008 BSM 135i
Default 07-01-2019, 07:02 AM
Does the Xtreme Twin Disc clutch allow enough slip to take advantage of the clutch delay solenoid? Iím using a M-Factory Twin Disc and have thought about the clutch delay, but it seems to be a little too grabby.
The clutch delay solenoid can go reallllllly slow, so I think so. But I couldn't get it to work right. When I dialed the slip to be very slow, it started to affect the clutch during shifting (when it was supposed to be OFF). I've heard it is because it's the MAP Performance device and not the true version from Magnus Motorsports.
Thanks man! I appreciate the support.
TimboBlackkers TimboBlackkers is offline
Car: '08 135i MT
Default 07-09-2019, 04:33 PM
Love the vids Jake. Keep it up.
I definitely think that car can go sub 10.5!
When are you hitting the track again?
Default 07-09-2019, 04:42 PM
I'm not good with 1/4 mile. I can't launch, I'm not good at pedal modulation.
Terry is very experienced with the 1/4 mile so he'll do that. I just do the 1/2 mile stuff cause he doesn't want to go 170mph+
luchocamp's Avatar
Default 07-09-2019, 05:35 PM
Congrats .... 139mph is amazing fast 30psi N54 is strong !
Keep it up
10.64 @129mph, MHD Custom + #LUCHOJB4, E40 + meth ~ Drag Track online set up on instagram @luchocampusano ➡
Car: 2008 BSM 135i
Default 07-10-2019, 08:09 AM
Thanks! I think I can get closer to 10.5 as well. I'd like to go back in the next month or so, but would be faster if I wait until the weather gets colder in September.
Keep it up
Thanks! I see you on the Dragy boards and on Instagram. You've got the short track down for sure, which is what I need to work on.
Raginge93 Raginge93 is offline
Car: 07 335i
Default 07-18-2019, 11:55 PM
Nice. Congrats on 10s! Btw, I would love to know the specs on your drag wheels.
Car: 2008 BSM 135i
Default 07-19-2019, 07:47 AM
Thanks! The rear wheels are OEM BMW Style 68s from the rear of an E46. They have 275/40/17 Mickey Thompson ET Street R tires on them.
