(#1976)
cahhlosr7 cahhlosr7 is offline
Car: kia stinger 3.3tt awd
Default 04-05-2019, 02:34 PM
Hi terry, can you check out my logs to see if everything is running good? map 3, 93 oct + e85 mix. thanks
Default 04-05-2019, 10:10 PM
Looks strong, no issues. Go kill some Q50s.
Default 04-06-2019, 07:03 AM
appreciate it thank you!
BMS Fanboy
Car: 2019 Kia Stinger GT RWD
Default 04-06-2019, 01:12 PM
@Terry
A little LAP bird is claiming you're "spoofing IAT to get more boost" and how thats a bad idea...
What say you?
Default 04-06-2019, 02:29 PM
With the optional IAT wire we alter IAT for more or less boost, and more or less timing. Very useful adjsutment in some unique situations but not good for all situations.
Would need a link to Laps post to offer a more specific reply to their concerns.
hoserama hoserama is offline
Car: 2019 Kia Stinger GT1
Default 04-06-2019, 03:17 PM
Terry,
Can you check my logs for Map1 and Map2? Everything felt fine but wanted to validate.
Default 04-06-2019, 03:24 PM
Originally Posted by hoserama
Terry,
Looks fine to me!
etats etats is offline
Car: Stinger 3.3T
Default 04-07-2019, 05:06 AM
Can't you make the pops exhaust sound via JB4?
BMS Fanboy
Default 04-07-2019, 08:52 AM
Unfortunately, it was said in private chat. To be clear, it wasn’t David...just someone who thinks LAP is the only way, and tries to find anything wrong with you and your product. I do wish his concerns were expressed publicly so you could address them yourself. This is also the same person that said the JB4 doesn’t display accurate boost numbers because it reads it from the ecu.
But back to the OP, it was in regards to DaBears running a 12.1 with JB4; this LAP person was saying DaBears should’ve been faster given his mods, but then went on to say something about running 19psi, and what you’re doing with IAT is bad.
RUFFSTUFF RUFFSTUFF is offline
Car: 2019 STINGER GT2
Default 04-07-2019, 10:39 AM
Originally Posted by P4RTYH4RTY
..but then went on to say something...
That familiar sound of jealousy...
CeramicGT2 CeramicGT2 is offline
Car: 2018 Stinger GT2
Default 04-07-2019, 06:17 PM
Can I get this log checked out? Getting hotter here in AZ and I want to make sure Map2 is looking good.
Default 04-07-2019, 07:55 PM
Looks fine to me. A little timing movement but expected for the fuel and conditions.
Default 04-07-2019, 09:56 PM
Thanks Terry. Still doing better than if I was on Map1?
Soccerstyle Soccerstyle is offline
Car: Kia Stinger
Default 04-08-2019, 08:03 AM
Terry, can you check this log, map2 93oct
Default 04-08-2019, 09:09 AM
Yes I think so.
Default 04-08-2019, 09:10 AM
Octane to boost looks great. Boost is moving around a little bit, but nothing major. What mods?
MekstingerGT MekstingerGT is offline
Car: 2018 Kia Stinger GT
Default 04-08-2019, 10:35 AM
I want to try boostane. I'm not getting a consistent reading when filling up with e85. What are the tips for boostane? I know theres a chart but how much do I out in for a full tank?
BMS Fanboy
Default 04-08-2019, 11:19 AM
Chart shows it all; depends on starting octane and desired octane.
Car: Kia Stinger
Default 04-08-2019, 12:00 PM
K&N intake, magnaflo exhaust. I adjusted stock plug gap to .25
Default 04-08-2019, 01:28 PM
OK probably fine.
Okierican Okierican is offline
Car: Kia Stinger GT2
Default 18' Stinger GT2 blowout - 04-08-2019, 08:03 PM
I've had the JB4 installed for a few months now and everything worked perfectly. It wasn't until recently that I started having problems around 8-10 psi, the car starts blowing out. Once it gave me a check engine light with misfire code. I did a log and every time it happens, the app freezes and it stops logging at that point. Running the latest firmware and last updated app on iOS. Running Map1. Mods on the car are:
NGM Intakes
Borla Catback
SSR Midpipes
JB4/fuel wires
I've attached the last log. Can someone take a look at it and help me figure out what is up with it?
Default 04-08-2019, 08:18 PM
Common issue when plugs are faulty. What plugs and gap?
Default 04-08-2019, 08:29 PM
I was hoping you said that. Using stock plugs gapped at .025. I did get some Densos 5346. Will install tomorrow for sure. Thanks @terry
Default 04-08-2019, 08:45 PM
What should I gap the Densos 5346 to? .026?
BMS Fanboy
Default 04-08-2019, 08:56 PM
.022
