Peter340's Avatar
Peter340 Peter340 is offline
Car: 2018 BMW 340i xDrive
Default 08-27-2018, 12:59 PM
Originally Posted by imsorussian
Any one hs any info where can i get Meth around NYC area?
SK-Speed on Long Island has 100% methanol.
Bullitt1841's Avatar
Default 08-27-2018, 01:38 PM
Originally Posted by Wickedowesix
Update
Currently on e50, dual CM7 100% meth, 40 additive
Here is a 5th gear pull log
Stock flash, still?
Wickedowesix's Avatar
Car: 540i G30
Default 08-27-2018, 05:17 PM
Originally Posted by Bullitt1841
Stock flash, still?
Yes sir. OEM flash tune
Car: 540i G30
Default 08-27-2018, 05:39 PM
Originally Posted by MasterYous
Is your only bolt-on that p1pe you mentioned? That is some good stuff there, for a basically stock car, if so.
I am on e20, 50/50 water/meth and additive 40 and having the stuttering /closures or misfiring (still not sure which it is) others have mentioned. At additive 30 all is well, but obviously I don't get the same power numbers you show at 40. I have seen a lot of split opinions on whether to keep the 50/50 mix or go 100% meth (safety concerns), as well as debates about nozzle size. My nozzles are the same size as yours.
Want to get to where you are. What are your other meth values for min/max RPM and your min flow boost? Have you modified any other meth values (trigger, etc?)
I'd honestly do staight 100% meth. I have meth trigger at 8psi.
BMW After BMW
Car: BMW M240i
Default 08-28-2018, 07:33 AM
Thanks for replying. Looks like your settings are similar (save for meth mixture). I'll wait to see what support says as well but your #s look very promising.
Car: 540i G30
Default 10-15-2018, 05:50 PM
Car is still running strong on e50.... just thought id keep you guys updated
jrdoming jrdoming is offline
Default 10-16-2018, 04:26 AM
How's the overall smoothness of the driving experience? Still on the fence over jb4 + meth vs straight ecu tune.
2017 340i M Sport. JB4
imsorussian imsorussian is offline
Car: 2017 BMW 340i Xdrive
Default 10-16-2018, 07:03 AM
I can’t speak for ecu tune. But running map6 or map7 with meth on my ‘17 340i xdrive is fairly smooth. No issues and its quick
Default 10-16-2018, 07:37 AM
Get meth, then stack the ecu tune on top of your Jb4.
Default 10-16-2018, 06:03 PM
Does the BEF come with the same features that are being offered on ecu tunes in terms of not incrementing the flash counter and maintaining the same CVN? Not sure if this can be answered at this point.
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 10-19-2018, 05:11 PM
Iím 1 click away from meth I keep going back and forward with it. Someone convince me.
Default 10-19-2018, 05:41 PM
I went from 12.2 to 11.8 in just first run on pump 93 and 50/50 meth
I seen guys getting to 11.1. Meth kicks ass
HitmanHearns HitmanHearns is offline
Car: 2016 340i
Default 10-19-2018, 06:14 PM
All we want is e40.
2016 340i M-Sport |JB4|ER DNPIPE|BMS Intake|
dRDiesel's Avatar
Car: BMW
Default 10-20-2018, 10:32 AM
Nice what additive setting and how fast did you pass the 1/4 (mph)?
Default 10-20-2018, 11:15 AM
Additive 50, i need to work on trap speed
Default 10-21-2018, 06:01 AM
What mods are you running?
Default 10-21-2018, 06:04 AM
**, intake jb4 and meth
Default 10-21-2018, 06:08 AM
So crazy how powerful meth+jb4 are
Default 10-21-2018, 07:33 AM
Mine has xdrive and on prepped track ( stock tires) i slip all the way into 2nd
Default 10-22-2018, 08:22 AM
Jeez, that is nuts LOL.
Default 10-22-2018, 12:16 PM
Maybe nuts, i want trap speed 122
Car: 2010 535
Default 10-24-2018, 06:21 PM
youll need over 500whp for those traps
f9kandy f9kandy is offline
Car: M140i
Default 10-25-2018, 04:10 AM
Or an M140i Ok so I'm 0.21 mph short of 122!
Default 10-27-2018, 06:31 PM
What are your mods, fuel and settings?
Car: 2016 340i
Default 10-27-2018, 07:20 PM
What is the curb weight of your vehicle? Online states 140i’s weight around 3300. That makes it 300 pounds lighter than our 3 series, right? Dang, that’s pretty good.
I think the best trap speed I’ve seen on this forum for a 340i without meth was 117 (intake JB4 ******** and 93 octane). So this might make sense?
I agree with the above, please share your JB4 settings
