KPDcompany's Avatar
KPDcompany KPDcompany is offline
Car: E90 2008 335i
Default 05-16-2018, 01:28 PM
It's 599 for just manifold. You can try to cap injectors but not sure if or how that could be done. Has 1/4 fitting for bov.
If you were interested, we could come up with some block off plugs, use o-rings on both sides, but you would have to have the fuel rail installed to do this. These could easily be printed for cheap.
Email - contact@kpdcompany.com
2008 335i Sedan M-Sport - Auto / M3 Body Conversion / JB4 E85 BEF / BMS DCI / BMS OCC / VRSF CP-HKS SSQV / Forge FMIC / KPD Bucketless LPFP / Muffler Delete / Poly Rear Bushings / M3 F&R Arms / StopTech SS Brake Lines
Default 05-16-2018, 01:44 PM
Ah. So what's the weight of manifold + rail? Stock is ~6-8lbs if I recall correctly.
N54 | Build Thread
Default 05-16-2018, 02:59 PM
Looks to be almost 11lbs.
Default 05-16-2018, 07:08 PM
Not bad for metal!
N54 | Build Thread
Default 05-16-2018, 09:13 PM
About the same weight as stock intake + a PI spacer.
07335i's Avatar
07335i 07335i is offline
Default 05-17-2018, 01:48 AM
Originally Posted by Steve @ BMS/Fuel-It!
We'll have these up on our website tomorrow with a plethora of options.
question, if I already have the Fuel-It Pi kit with retunrn line and fuel line upgrade with an ethanol sensor installed, will I need any additional option or anything? basic kit??
one more question is... Can I use your orginal PI kit with this metal manfold for direct port meth injection???
Trickcruiser's Avatar
Default 05-17-2018, 03:51 AM
We have one on the way and will be doing a step x step very soon!
psixtc's Avatar
psixtc psixtc is offline
Default 05-17-2018, 07:46 AM
I wish it were being installed on the Evil1 instead of whatever you're putting it on
Default 05-17-2018, 09:04 AM
You could, you'll just need to get the DPMI version of the kit on our website with the meth line.
http://www.fuel-it.com/phoenix-racin...ort-injection/
Or if you've already purchased the manifold additional upgrade options for meth lines, fuel lines, ethanol sensors, ect. these manifolds can also be found here...
http://www.fuel-it.com/phoenix-racin...grade-options/
Default 05-17-2018, 11:42 AM
Just drive her back so I can throw one on! It’s been what, a month since I made that thing throw ALL the codes? LOL
Default 05-17-2018, 04:23 PM
Have several orders in. Hope to get them out tomorrow or Monday. Waiting for the FuelIT injector kits Steve sent us to show up.
chadillac2000's Avatar
Car: 2008 535i
Default 05-18-2018, 08:03 AM
Has anyone tried running the OEM engine cover with this manifold to confirm whether or not it fits? I'm not opposed to trimming, as I've already had to hack mine up a bit to accommodate the top mount.
treehouse treehouse is offline
Default 05-18-2018, 10:57 AM
Does this manifold add more space around the OFHG? Can you remove the OFHG without removing the manifold?
BOosted 335i's Avatar
BOosted 335i BOosted 335i is offline
Meth Addict
Car: E90 TiAG 335i Sedan
Default 05-18-2018, 12:04 PM
Can we get some pics of the connections underneath of manifold and inside throttle body?
Default 05-18-2018, 12:22 PM
You will still need to move it to reach the bolt.
The phone flash and the darkness coudln't line up, every time I took a pic of the inside it was blurry. I got this photo though, so I hope that helps a bit.
Meth Addict
Default 05-18-2018, 01:51 PM
Yeah great thanks.i was wondering what it looked like from those welds on the tubes if it's smooth inside.
teggei2 teggei2 is offline
Default 05-19-2018, 10:13 PM
I just placed an order with Platinum Package, 750cc injectors, and JB4 PI controller. =)
Default 05-20-2018, 05:07 PM
PrzeChuj PrzeChuj is offline
Car: 08 335i
Default 05-23-2018, 06:58 PM
Steve your price on your site is $699 for the manifold , your post says starting at $599 ???
e92 MT 08
Single T
FBO
Dual 450 lpfp
BEF
MeTH!!!!!
E85 100°/¤
SPANKY's Avatar
SPANKY SPANKY is offline
Car: 2008 335i
Default 05-24-2018, 03:23 AM
What's the difference with this and sharp customs.they are selling same intake it seems at 100.00 less.
E90 SEDAN '08
-SiNGLE TURBO AUTO TRANS*FSB G5 ISO*100%METH**FUEL iT!STAGE 2*ALPiNA FLASH-
-NGK PLUGS*BMS OCC*RB VALVE-
-E85 MHD FLASH-
Default 05-24-2018, 08:12 AM
Enter the code PHOENIX at checkout for $100 discount.
Default 05-24-2018, 08:27 AM
Similar intakes are made in China. We ensured our supplier made some changes to improve fitment, and we also provide a USA hardware package with better orings (the ones they come with don't seal right). We're not highlighting all the fine details because then the next China company will just copy what we fixed.
SPANKY's Avatar
Car: 2008 335i
Default 05-24-2018, 05:51 PM
thanks for the info.
E90 SEDAN '08
-E85 MHD FLASH-
Car: 2008 535i
Default 05-29-2018, 07:20 PM
Mine showed up earlier today. Everything was packaged up nicely:
Out of the plastic wrap. Welds don't look too bad on the exterior, nor does the finish. It's not as pretty as the FF polished units, but its not as expensive either, and it still beats the look of the stock waffle.
Here are some interior shots illuminated by the LED on my iPhone X starting with where the injectors will sit. The white streaks seem to be some type of residue that has dried on the black finish during the manufacturing process -- I'll try to remove this before installation.
Fuel rail looks good too.
USA hardware looks nice, along with o-rings that should hold up to the heat.
If you ordered the fueling kit from Fuel-It! the package will also include what's shown below. I'm a big fan of how Fuel-It! packages all their parts.
Because I already had upgraded Fuel-It! lines from the tank to HPFP with an ethanol sensor, I went with the upgraded camlock style line that replaces the line shown above and will hook up to my ethanol sensor + PI fuel rail + HPFP.
I also added a JB4 PI controller to finish off this setup.
I have a replacement HPFP in hand, should be receiving my stage 3 bucket from Fuel-It! sometime next week, and have hopes to install everything over the next few months as time allows.
Default 05-29-2018, 08:03 PM
Really awesome pics Chad, thanks again! Can't wait until you strap these on so you can actually turn it up a bit
