Xdrive35i2014 Xdrive35i2014 is offline
Car: X1 Xdrive35i
Default Are my expectations realistic? - 06-09-2016, 08:36 AM
Hey guys, newbie here. I am about ready to drop some serious cash to buy these mods for my X1 Xdrive35i:
1). JB4-Type B harness + USB cable
2). ER chargepipe
3). ******* ******** (n54 tuning?)
4). ER Intercooler
5). Pure Stage 2 Turbo
6). N55 PURE High Flow Inlet Pipe
7). N55 Diverter Upgrade DV(Plus)
Would these mods allow me to get to the 420-450whp range on 94 octane pump gas (no E85)? My car is my daily driver thus I want to run it conservatively on Map2 or Map6 with target max boost at 15 PSI.
Thanks in advance
bleedsblue0023's Avatar
bleedsblue0023 bleedsblue0023 is offline
Default 06-09-2016, 08:49 AM
Is meth out of the question? Running a PS2 turbo without additional fueling is a bunch of cash for not maxing the unit out. Maybe put port fuel on top? Regardless I think you need a bigger fuel pump. Hopefully Steve will chime in. I have the stock turbo maxed out at 19.5psi on e65 making only 20 or 30 less whp than your goal.
Houston, TX
Jet Black 2011 335i Sport 6MT:
Mods:
BMS Intake, JB4 Iso, BMS E85 BEF, CPe Chargepipe, ETS 5", Megan Racing turbo outlet, BMS OCC, SS Brake Lines, BMS CDV, MFactory LSD + mounts, 335is clutch, MFactory SMFW, 650i finned diff cover, Pure Inlet, Fuel-it Stg2 LPFP + Plat TBI, E46 Trans mounts, Turner Pedals, Mishimoto wheel lugs, Turner 10mm spacers, Msport Interior, M3 armrest, M3 Control arms, EvoRaceWerks F30 TIC pipe
Anthony235's Avatar
Anthony235 Anthony235 is offline
Car: m235i
Default 06-09-2016, 09:14 AM
Yes, but he'll be doing it on pump gas and less boost than you. Less boost and more power is always a good thing.
If he wants to do some extra fuel later he has room to grow.
I see no problem with his logic if his goal is to have a ~430hp car that pulls all the way to redline and does it with less boost than we can on stock turbo.
Anthony235's Avatar
Car: m235i
Default 06-09-2016, 09:09 AM
Yes, I think that's realistic from what I've read and seen other people do on N55 F-series with PS2 turbo and pump gas. You'll make more power with PS2 @15psi than stock turbo @15psi.
I would recommend the Bluetooth Connect kit over the USB cable though.
Car: X1 Xdrive35i
Default 06-11-2016, 03:54 PM
thanks for the headsup. I have ordered the Bluetooth connect kit as well as the usb cable.
Originally Posted by Steve @ BMS/Fuel-It!
The mods you have listed will definitely support those power goals.
For fueling, it depends on which year the X1 is and which HPFP it has. If it is one of the new HPFP's, it may not be able to keep up, you'll have to see. But that is also provided the fuel has enough octane to support those power levels, all we have access to is 91 octane and it's horrible, so we don't have an data on those types of power levels on pump gas.
hmm, i thought the E84 X1 uses E series components. My X1 is a 2014 model... I will get the car built first then when i am playing around with Map 6, then i will know if I will run into any fueling issues.
Just want to let everyone know i have just purchased the mods. I will probably go FBO first to make sure things work out before installing the PS2 turbos. Thanks everyone for the help!
Default 06-09-2016, 09:32 AM
Default 06-09-2016, 09:41 AM
94 octane gas would be about E20 if you were blending.
Houston, TX
Mods:
keyap keyap is offline
Car: N55 135i
Default 06-12-2016, 03:17 PM
You may be able to tell by checking realoem - possibly the same HPFP part no?
Car: X1 Xdrive35i
Default 07-20-2016, 01:08 PM
hey guys,
I would really appreciate some help here. I have decided to install all the mods in one go. What map should i run to make sure things are working properly? Can I just use Map5 and log?
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 07-20-2016, 02:18 PM
Originally Posted by Xdrive35i2014
hey guys,
I always start with map 4 for a first few logs then Map 5, but yeah map 5 should be ok just make sure you log alot. I generally use it to map custom map 6's.
Mods: Stock for now
Car: X1 Xdrive35i
Default 07-20-2016, 07:06 PM
thanks. Another question. I still have JB4 at home right now. Should i clip the diode now to prepare for flashing to the ISO firmware? Can I not flash to to ISO firmware after clipping the diode?
Lowon's Avatar
Car: Bmw M2
Default 07-20-2016, 09:21 PM
Sorry I'm not particularly familiar with iso jb4 stuff in particular as I'm an F series owner and have never worked on E series iso jb4's in terms of tuning.
Mods: Stock for now
Car: X1 Xdrive35i
Default 07-21-2016, 08:44 AM
No worries man. I will hold off on flashing to ISO. Gonna drive for a while on Map2 to enjoy the nice power increase from stock before I look for more power!
N55x1 N55x1 is offline
Car: N55 X1
Default 07-20-2016, 08:50 PM
Clip the diode and then install and update to the iso firmware. Hpfp in X1 can't handle high e85 levels, but you can run pump gas ato 18psi peak levels. Get the n20 tmap to run map 1 or 2 and hold more boost to redline or make custom map 6 after you test and log to make sure all is installed and no boost leaks.
Car: X1 Xdrive35i
Default 07-21-2016, 08:42 AM
Thanks for the reply! In BC Canada, there's no E85 around. I am only planning to run pump gas. As you said, i am planning to make my custom Map 6 after i have made sure things are installed properly.
Lowon's Avatar
Car: Bmw M2
Default 07-25-2016, 10:53 PM
There's an E85 station in Vancouver.
Mods: Stock for now
Default 07-26-2016, 04:35 AM
Awesome. Let us know what you end up putting down.
Houston, TX
Mods:
Anthony235's Avatar
Car: m235i
Default 07-26-2016, 07:21 AM
Congrats! Keep us updated!
Car: X1 Xdrive35i
Default 07-27-2016, 01:09 PM
I just got a call from my shop. They said the charge pipe i have ordered does not fit my X1. I thought all N55 charge ***** are the same? Could someone please help? I will be picking up my car today after work... I guess i will have to run the stock charge pipe for now.
This is the charge pipe i have ordered for my car:
N55 E-Series 2011+ ER Charge Pipe (N55Z1)
http://www.n54tuning.com/n55-2011-er-charge-pipe.html
rwalker rwalker is offline
Default 07-27-2016, 01:25 PM
realoem says that all the E-Series (E82, E84, E90) all use the same charge pipe
did your shop offer specifics about fitment?
maybe DIY, it's not that hard, just fiddly
rwalker@rwalker.com (I really dislike private messaging)
Car: N55 135i
Default 07-27-2016, 02:12 PM
That's the CP I run - no problems with fitting on a 2011 E series.
Car: X1 Xdrive35i
Default 07-28-2016, 05:49 PM
My shop made a mistake, everything fits... I just got my car back. Holy **** it feels almost as fast as my E63 M6! It feels like a completely different car! Right now I will just leave JB4 on Map 5...
I will post a log in the support section to see if there are any issues.
Lowon's Avatar
Car: Bmw M2
Default 07-28-2016, 06:47 PM
Awesome!
Mods: Stock for now
MR.M MR.M is offline
Car: 2018 BMW M240I 8sp Auto
Default Maps - 10-03-2020, 12:43 PM
hi i recently got a ******* ******** for my m240, wondering which map i should run on the latest software for jb4? i dont have any other supporting mods. also i dont mind doing a e30 mix on map 5 just would like to know if the car needs any other supporting mods.
