(#1301)
Eric SS's Avatar
Eric SS Eric SS is offline
Car: 2013 335i M Sport
Default 08-25-2014, 11:50 AM
Hey Terry, with Map 5 up and running, do I still need to adjust the open loop setting when running E85 with my Flex Fuel connector or do I just set it back to 0 and let the Jb4 autotune? Thanks.
2011 335is JB4- Gone
2013 F30 335i M-Sport JB4
Default 08-25-2014, 12:01 PM
Open loop does not adjust itself on the N55 and should be left at 50 or 60.
copperman05 copperman05 is offline
Car: BMW M135i
Default 08-25-2014, 12:33 PM
Thanks for the update.
Chaddy74's Avatar
Chaddy74 Chaddy74 is offline
Car: M135i
Default 08-25-2014, 04:29 PM
2.8 logs
M135I ER Down-pipe & charge pipe ,Milltek full system,Wagner Performance Intercooler AFE Stage 2 Intake Pure stage 1 Turbo & Quaife LSD
Default 08-25-2014, 04:32 PM
FF is still too high and learning down. I'd just lower it to say 80 to speed that process up.
Chaddy74's Avatar
Car: M135i
Default 08-25-2014, 04:34 PM
ok mate !! you want more data ? im at the track !!
Default 08-25-2014, 04:37 PM
Sure! Timing seems solid. Can't hurt to take a run on map 7 just for a datapoint. I'd raise open loop to 60 also.
Chaddy74's Avatar
Car: M135i
Default 08-25-2014, 04:45 PM
Map 2 2.8 lowered FF to 80 forgot to turn traction control off in one
Default 08-25-2014, 04:47 PM
Still needs to go lower. Maybe 55.
Chaddy74's Avatar
Car: M135i
Default 08-25-2014, 04:59 PM
2.8 map 7 open loop 60 no traction !! i raised failsafe to 19
Default 08-25-2014, 05:02 PM
I don't think that setup will work well with colder weather but with the current weather and fuel mix seems OK for track use.
For now I'd lower FF to 50 to further speed up wastegate adaption. I'd also raise the boost safety to 20psi.
Chaddy74's Avatar
Car: M135i
Default 08-25-2014, 05:05 PM
i will lower ff to 50 and go back to map 2 until further notice !! car was happy enough tho on map 7
Chaddy74's Avatar
Car: M135i
Default 08-25-2014, 05:13 PM
BTW throttle is very good
Default 08-25-2014, 05:21 PM
If you're doing 1/4 mile runs I'd be interested to know how much MPH on average map 7 is adding to your trap speeds vs. map 2.
marcoac14 marcoac14 is offline
Car: BMW 320i
Default 08-25-2014, 05:22 PM
Terry, can you tell us how you know when to raise or lower the FF parameter? Or is this top secret?
Default 08-25-2014, 05:27 PM
It's just basic tuning. If PWM is above FF it's too low. If PWM is below FF it's too high. The JB4 adjusts it on its own provided the dynamically computed FF curve is a good fit for the situation.
Chaddy74's Avatar
Car: M135i
Default 08-25-2014, 05:36 PM
i will run some vbox testing and advise results
Car: BMW 320i
Default 08-25-2014, 07:39 PM
I see. Thanks for sharing.
Default 08-25-2014, 08:41 PM
Thanks. Try to get some long runs too so we can see if boost spikes in higher gears as IAT goes up. If so I have a fix for that.
Chaddy74's Avatar
Car: M135i
Default 08-25-2014, 10:51 PM
HI T , I ran out of time to test map 7 but Vboxed Map 2 : Im having a heap of drama's getting off the line too much
0-100 4.61
0-400 12.43 @ 118mph
80-120 1.7
120-170 5.8
More testing to come !
ghostchili ghostchili is offline
Car: 2014 335xi
Default 08-26-2014, 07:58 AM
What fuel are you running with map 7?
Chaddy74's Avatar
Car: M135i
Default 08-26-2014, 02:24 PM
BP98 and 20% E85 which is about 10L to a tank. I only tested map 7 for one run but must admit the car did like it
Car: 2014 335xi
Default 08-27-2014, 06:37 AM
My car feels like it likes it but apparently runs lean.
Car: 2014 335xi
So what settings are we changing when we run the new firmware? Or is that still being determined?
Chaddy74's Avatar
Car: M135i
Default 08-27-2014, 07:13 AM
Post a log file ? I want to have a look at your timing values on Map 7 also
