Originally Posted by jamesmurray
Thanks for the info. Terry looked at my setup a couple of months ago, and everything is fine. At WOT everything works as it should, and meth is flowing without issue. The issue above is under part throttle pedal (30-40%), where the BM3 targets 15psi (ecu psi) but the jb4 is targeting little or no boost which is causing the oscillation at part throttle. The .csv is included in the first post. Thanks
James
the jb4 target is an additive target though no ?
surging/oscillation are also entirely different things, it's doubtful you're experiencing surge and the oscillation in boost pressure though noticeable in the figures, don't seem to be extreme (you're going from 9.5 to 10.5 give or take, even on my regular logs i see psi readings fluctuate by 0.5psi from timestamp to timestamp all the time)
again, if you're experiencing something you don't think is normal
it's worth it to check it out
do you have a gopro ? maybe a video would help clarify what you're seeing
