Philborland335i Philborland335i is offline
Default First log map 5 jumps to 4 - 08-21-2019, 01:26 AM
Hi folks,
New to this. Seems to drop to map 4 pretty consistently. New to this platform and the car is also new to me, any help and insight that can be offered is greatly appreciated.
Cheers - Phil
Default 08-21-2019, 02:51 AM
Should add..
Car running on 95 octane UK pump fuel, new shell helix 5w30 oil and new oil filter, new n55 spark plugs, new vanos solenoids, new cam sensors, vsrf ******* *********, turbosmart twin bov and chargepipe, bms intakes, vsrf inlets, oil catchcan, walnut blasted intake mani 7000 miles ago, new turbos 7000 miles ago. Drives perfect around town and on national speed limit roads, problems only seem to arise at wot or near it.
Would a bef sort this? Ripping my knitting this ��
Default 08-21-2019, 11:25 AM
Which firmware are you using?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 08-21-2019, 11:34 AM
Total noob to this. Car has Bluetooth kit installed - what's the easiest way to check firmware version? You have any incline on a possible cause?
Thanks in advance - Phil
Default 08-21-2019, 11:42 AM
Ok- so it's a used unit.
Firmware is located on top right of log.
Read this & update the firmware on your JB4 to current : E Series N54 JB4 - N54Tech.com - International Turbo Racing Discussion
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 08-21-2019, 11:46 AM
Thanks Dave
It's 28/02//2
Default 08-22-2019, 07:36 AM
Originally Posted by Philborland335i
Thanks Dave
It's 28/02//2
No problem- lets get you updated & then go from there
e92 AT 335xi 2.0
Doc Race Kit 6062
