(#26)
Nordic335IM3's Avatar
Nordic335IM3 Nordic335IM3 is offline
Car: BMW 335I N54
Default 08-10-2016, 01:43 PM
anyone with a solution to this?
its obnoxiously loud
does changing the bov spring to a lower rated one and/or tapping the
manifold with a bigger bov vacuum hose really work , as suggested by some?
Torgus Torgus is offline
Car: 335xi
Default 08-10-2016, 02:06 PM
I would try putting the correctly sized vac hose to the BOV. The stock line is too small per Tial specs.
Got Boost?
Car: BMW 335I N54
Default 08-10-2016, 02:55 PM
yes this is next on my list
S.W.G. S.W.G. is offline
Default 08-10-2016, 05:08 PM
Mine sounds very similar. I upgraded to a 1/4" hose and outlet as well.
https://www.youtube.com/watch?v=RITzLCv4WB0
Beemin Beemin is offline
Car: 2007 e92 335i
Default 08-10-2016, 07:21 PM
I have the hotside aluminum inlets along with aluminum outlets and I get this sound with stock DVs venting to atmosphere.
Just like the OP's video, the high pitch sound happens a split second before the standard DV/blow off sound and mind sounds like it's coming from the passenger side. It's almost like the DV's can't release quick enough.
I'm going to try the 1/4 hose and barb to see if that helps.
Car: BMW 1M Coupe
Default 08-10-2016, 07:43 PM
to chime in, i'm running Pure turbos with VTT inlets and it sounds like that too! car have been running fine, 27PSI with no issues for around 10,000kms so i wouldn't be too bothered by it. logs look nice as well. I would say that the noise is probably just the character of the inlets.
Car: BMW 335I N54
Default 08-11-2016, 02:57 PM
https://www.youtube.com/watch?v=QYbf-SWsz14
I think its too loud.. the old pssss sound was better..
Grunt Grunt is offline
Car: 335is
Default 01-01-2020, 06:41 PM
Thread revival, sorry......
I've been researching this since I put my inlets on a few months ago. I just found this thread and this video is exactly the sound I have that I do not like at all. MMP inlets on VRSF c.p. and Tial bov on custom tune at 22psi and all the other usual bolt ons. Has anyone found a cure for this possibly? Different spring than standard in the bov? Different bov?
nyt nyt is offline
Car: 335ix
Default 01-01-2020, 08:11 PM
I think it's a resonance from the silicone intake tubing and nothing you can do aside from running hard lines will fix it.
2010 335ix - speedtech, 6466g2, cams, ported head, built bottom end, 7.5in hd ic, jb4, pi, dual 535s w/ external fpr and return, upgraded 6hp21+cooler, pr coils
iqraceworks's Avatar
iqraceworks iqraceworks is offline
Car: 355i
Default 04-11-2021, 03:23 PM
I know this is an old thread...but did anyone find a "fix" for that annoying squealing Tail BOV noise after installing inlets? Just got mine on...and instead of the nice "wooosh" with the stock inlets, I get that high pitched squealing noise now with the aftermarket silicon inlets......it sounds horrible!!
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Down-p1pes, Bilstein B12 Prokit Suspension,G-Plus FMIC, MHD Stage 2+ tune, xHP stage 3 transmission flash.
Car: BMW 335I N54
Default 04-11-2021, 04:26 PM
Got rid of most of it.. now only a bit on letting of from very low boost.
lowest spring , tapped intake manifold , 1/4" vacuum line
E92 N54 2007 (kline)
ER Chargepipe + TIAL BOV with 1/4" tapped manifold , MMP IN & OUTlets, Chargepipe CM10 nozzle with 93% Ethanol(soon going pure meth) , JB4 MHD custom map 6, Shell Vpower 100 , D.P + straightpipes, 5" stepped wagner FMIC , 0.5 mm NGK 95770
öhlins shocks & springs , M3 swaybar front & other M3 bits, PCV lowside: Misimoto ccan Ext RB blocked ports, highside: BMS ccan , Solid Diff Brace, 20" wheels,Android HU,
Car: 355i
Default 04-11-2021, 06:39 PM
I'm running the standard 10psi spring......what did you end up going with?
Car: BMW 335I N54
Default 04-12-2021, 08:09 AM
I think the lowest spring is about 7 psi ?....
have you made a video of your bov sound?
Car: 355i
Default 04-14-2021, 04:51 AM
Listen to this video....sounds exactly like this, exactly. Guy has 1.75 inlets and a Tial BOV.
Fil 11 08 2016 23 27 48 - YouTube
I put a 1/4" ID line on the BOV last night.....no change in sound. My next step is the lighter 7psi BOV spring.
It sounds horrible......like a high pitched squealing parrot under the hood.
Car: BMW 335I N54
Default 04-14-2021, 06:32 AM
funny, thats my car and video :-) , anyway it does not sound like that anymore... I have the mmp hotside inlets, and outlets , tapped manifold with the 1/4" hose, and the 7 psi spring... I cant do a video as its currently on jackstands for some TLC , but I will make a new video when I can. I think you should try for the lower spring, it will make the bov open on idle but its more snappy. And update this tread then
Car: 355i
Default 04-14-2021, 07:20 AM
Yep...that 7psi (black) spring should be coming in by this weekend. I'm crossing my fingers that it gets the BOV to sound "normal" again.
I will definitely post an update after I install the spring.
nyt nyt is offline
Car: 335ix
Default 04-14-2021, 09:09 PM
The spring isn't the issue. Running the proper pressure spring and it will still sound terrible.
The solution is to use proper piping for inlets or run the hot side shorties.
Or just scrap the tt stuff and put a nice big single on there.
Car: 355i
Default 04-15-2021, 04:53 AM
Why would the material of the inlets (plastic/silicone/aluminum) affect the sound of the BOV that's on the complete other end of the turbos? The air is sucked through the air filters, through the inlets, through the turbos, out the outlets, through the FMIC, down the chargepipe (with BOV), and then into the throttle body.
How do the inlets on one end of the system, affect the sound of the BOV on the complete other end of the system? Just trying to make some sense out of it.
nyt nyt is offline
Car: 335ix
Default 04-16-2021, 12:42 AM
With no other changes but inlets, they completely change the sound. I think there's some kind of resonance they're introducing.
Car: 355i
Default 04-19-2021, 04:41 AM
Well, I put the new 7psi spring in the Tial BOV last night. It's definitely lighter, it's fully open at idle, which I'm not sure I'm a big fan of....but I can always switch it back to the 10psi spring.
Long story short......same screeching owl/chicken noise when I'm in boost and let off the throttle and the BOV opens. Larger 1/4" ID line, and 7psi spring.....no change at all. Kind of frustrating...it used to sound so good with the stock inlets on the car.
At this point, I guess I will just have to chalk it up as some strange resonance caused by the silicone inlets....I can't think of any other explanation. I guess I will just leave it until I get some different turbos later this summer....probably just put some PR relocated inlets on the car while I do the turbos. From everything I've read, they will get that nice "whooosh" sounds back from the BOV.
nyt nyt is offline
Car: 335ix
Default 04-19-2021, 05:09 PM
Lol, you don't like the sneezing sound?
Stock location inlets are obnoxious. Probably better for IATs, but otherwise annoying. Lots more room in some key places without em. I'm glad I don't have to deal with them anymore.
Car: 335xi
Default 04-20-2021, 10:16 AM
Yeah passenger side inlets are the way to go. Driver's side suck(no pun intended) for a variety of reasons.
You will have also moved your coolant tank for the future when you go single turbo an added plus
Got Boost?
Car: 355i
Default 04-22-2021, 05:00 AM
What brand of relocated inlets do you suggest? I would going to get the PR ones, but the more I read, the more it sounds like lots of people have fitment issues with them.
mega mega is offline
Default 06-18-2021, 03:48 PM
vsrf relocated inlets with tial bov and I too now have this sound, at least I know I'm not alone
Car: BMW 335I N54
Default 06-19-2021, 12:58 PM
does yours howl under all conditions or just certain rpm/load levels?
Mine seem to only make a slight toot when letting of in the lower rpms..
if ppl could make a video when it sounds worst and link it here..
