(#3926)
Default 12-29-2020, 02:33 PM
You enter the settings manually in the first post.
bosaad bosaad is offline
Car: Kia Stinger
Default 12-29-2020, 11:24 PM
These settings are not mentioned? Are the values ​​correct for my stinger 2.0L?
ENreviews ENreviews is offline
Car: 2018 Kia Stinger GT2
Default 12-30-2020, 07:57 AM
Originally Posted by ENreviews
Okay, I was able to snag some logs this weekend 3 pulls 40-100, on closed roads.
I run 93 octane from BP so there are some fuel additives, HPS dual CAI, I also have Agency Power Dual BOVs, other than the JB4 and the mentioned mods the car is stock.
Please let me know if the logs appear to be good.
Terry, did you get a chance to look at these logs?
twister68's Avatar
twister68 twister68 is offline
Car: 2017 Q60 RS
Default Terry Please can you do a Log Healthcheck - 12-30-2020, 10:21 AM
Terry I edited the file to get size down. Just looking to make sure all looks healthy after some issues with turbo flange bolts snapping during attempt to put in *********. Went back to stock *********.
Twister
Twister
2021 Genesis 3.3T
Siberian Ice
JB4 kit with EWGs MAP 2 94RON
Feeling the JB4 difference
Default 12-30-2020, 11:42 AM
Those are fine, and are in the photo in the first post.
Default 12-30-2020, 11:44 AM
Looks like I missed the post but runs seem fine to me. Boost, timing, and fueling all in check and as expected for map2.
Default 12-30-2020, 11:45 AM
Twister
Seems OK, fuel wires are attached right? A longer full throttle run would be more useful.
Default 12-30-2020, 01:42 PM
Thank you kindly 👍
twister68's Avatar
Car: 2017 Q60 RS
Default 12-31-2020, 04:33 AM
thanks Terry, will post longer run shortly.
Twister
2021 Genesis 3.3T
Siberian Ice
ANDEN10 ANDEN10 is offline
Car: Stinger AWD
Default 12-31-2020, 04:36 PM
Im curious, how can i use JB4 as my WMI controller/safety device while also running a full tune? And what are the specific details behind it, as in what will JB4 do if flow were to cut, will it be able to drop my full tunes performance in order to protect my engine or what?
I don't wanna just know how to get it to work id like to also know HOW it works
twister68's Avatar
Car: 2017 Q60 RS
Default Log for quick health check please - Longer full throttle 60-180kmh - 01-01-2021, 06:45 AM
Yes Terry with fuel wires, longer full throttle
Thanks Terry and Happy New Year to your and all JB4 team
Twister
2021 Genesis 3.3T
Siberian Ice
Stiletto's Avatar
Stiletto Stiletto is offline
Car: Kia Stinger GT2
Default 01-01-2021, 09:09 AM
Looks good for map2 on 93. Might be worth updating the firmware and trying FF = 60 to see how it reacts to more EWG offset.
Uploaded firmware 21/20//5, adjusted FF to 60. WOT pulls then falls flat around 5k rpm. Pulls strong otherwise.
Mangeski Mangeski is offline
Car: 17 2.0T stinger
Default Jb4 Bluetooth connection issuse - 01-01-2021, 05:39 PM
Hello, I just got my car back from the shop after over 30 days and now it will not connect. When i go on the jb4 app, only the boost guage works. Everything else is zero. Thoughts?
Default 01-01-2021, 06:29 PM
OBDII loose or backwards?
Default 01-01-2021, 06:30 PM
OK looks to be over boosting, back down to FF 50 for you. Or even lower if it continues.
Default 01-01-2021, 09:49 PM
I'll double check. I would hope the shop would mess with my wires but you never know.
Default 01-02-2021, 10:18 AM
Most likely the case. Guide has photos on how it's supposed to plug in to the JB4 also.
Car: Stinger AWD
Default 01-02-2021, 06:54 PM
I would like to make a product improvement suggestion. I have an android and we dont get a lot of information in the app, what I'd love to see is tooltip for each adjustable input as to what it does or affects and the input value meaning, i.e 100 = max 0 = off, as well as recommended settings. I'd also like to see and advanced users PDF containing the same info but more detailed so that users can learn about what the JB4 is actually doing and they can better tune their car accordingly with JB4.
I wanna maximize my JB4 tune and in order to do that I need info on what all the input values mean and what they affect, and I cant find anything on google that tells me if I put as an example "Auto Shift Boost Reduction"
Default 01-04-2021, 12:46 AM
They unplugged my main cable under the dash. Everything is back to working. Thank you for keeping me calm btw.
twister68's Avatar
Car: 2017 Q60 RS
Default Longer Run for Log Check Please Terry - 01-04-2021, 04:06 PM
Thanks Terry MAP4 with pro booster juice
Twister
2021 Genesis 3.3T
Siberian Ice
ValkyrieMedic ValkyrieMedic is offline
Car: 2019 Stinger GT2 AWD
Default Code 0068 - 01-10-2021, 02:21 PM
Got a throttle code (0068) after updating to v22_T4 and enabling Lagfix with setting of 70. Gonna back it back down to 50 and try again. Is this code what folks are seeing when dialing in this new feature?
Default 01-10-2021, 08:21 PM
Looks fine to me!
twister68's Avatar
Car: 2017 Q60 RS
Default 01-11-2021, 05:40 AM
Thanks Terry
Twister
2021 Genesis 3.3T
Siberian Ice
Mrjarrodcthompson Mrjarrodcthompson is offline
Car: Kia Stinger GT
Default 01-14-2021, 03:17 AM
Hi guys, first time post.
Q. Is there a way via the Phone app (or windows for that matter) to confirm that the OBD connector is connected and functioning with the JB4? Can't seem to find a status.
I have had intermittent issues with the OBD data showing up in the app. I'm not really sure why (all my kit is only a couple of months old - Kia Stinger GT) - nor what impact this actually has other than logging.
Andy-J-Knight Andy-J-Knight is offline
Car: Fk2 Civic Type R
Default 01-14-2021, 03:45 AM
Maybe worth making a specific thread for this but anyway, if your ODBII is really disconnecting then the JB4 will be losing visibility of multiple ECU parameters/sensor values that it needs to operate. It won't have any idea of what RPM you are at, water temps, trims, afr etc which will most likely cause you to drop into map 1 (if you are not running that already).
Probably worth checking the cable connection at both the ODBII port and the cable connector in the engine bay to make sure they are both properly seated.
Honda Fk2 Civic Type R | JB4 | Injen Air Intake | Scorpion Exhaust | Shadow Chrome Rota PWR's | Insta: @andrewjonknight
