andrew.g35.04@gmail.com andrew.g35.04@gmail.com is offline
Car: 335i 2009
Default Trans fault 50870 input signal error:tip-function - 09-18-2018, 09:52 AM
So we replaced the transmission and started getting this error the car goes into what should be drive but says m2 and canít shift thru the gears with the paddles or shifter and if I put it in ds it drives fine any help or insight would be greatly appreciated
G
Blackbeautyn54
kipitrl's Avatar
kipitrl kipitrl is offline
Car: BMW 335I
Default 04-27-2019, 10:00 PM
Hello, did you ever find out what that error code was? I have the same code just wont go into S mode
