Ballistic Ballistic is offline
Car: BMW 335i N54
Default Second O ring on throttlebody/chargepipe? - 09-08-2018, 01:10 AM
Hi all,
I installed my chargepipe + Tial BOV (unpainted 10psi spring) on my N54 yesterday. Connected the Tial with a 1/4 line directly to a new vacuum connection on the manifold.
I now have a whistle when boosting. It starts at about 4psi and is pretty loud almost all the way through the RPM band.
During removal of throttlebody+manifold, I found an O ring right under where the thottle body is supposed to be (it was laying on the hard to unclip electronics box)
I have no place for this O ring as i have not seen it before and i cannot place it anywhere.
It is not the O ring in the charge pipe, i already moved that over.
The only place they are talking about 2 O rings in the charge pipe: https://f30.bimmerpost.com/forums/sh....php?t=1236747
But this is for an F30 while i have an E91 N54.
I did not reinstall this ring. Could this be causing the whistle? Throttle body connection looks solid. It should be either this, or the Tial valve not closing fully.
Default 09-08-2018, 05:13 PM
Only 1 O ring should be on CP to Throttle body.
Default 09-09-2018, 09:51 AM
Maybe it got dropped by accident. Same size o ring is used for the oil filter cap
2007 e90 335i
Hexon turbos
Trebila Custom tuning
Car: BMW 335i N54
Default 09-10-2018, 01:44 AM
Thanks for the verification. I also asssume it was there by accident.
I used a single O ring and replaced the Tial valve with a new one. No more whistle
Case closed.
