(#3651)
Hyab00sta Hyab00sta is offline
Car: 09 335xi
Default 08-16-2018, 09:13 AM
Just did my MHD BEF using IEJOS BB2 pump map. I have an 09 335xi with DCI Charge pipe, Tial BOV, 7" IC and ******* **'s. I have the JB4 in map 5 and everything is working perfect. when running E30 instead of straight 93oct does the timing and fuel adapt on its own to the e30 mix or is the fuel and timing for that map set at constant tables for boost and rpm? thanks
Default 08-16-2018, 09:30 AM
The JB4 map5 should adjust for it automatically. If you have any issues then post a log and we can confirm.
cjordanc7's Avatar
cjordanc7 cjordanc7 is offline
Car: 08 335i
Default Log - 08-17-2018, 05:09 PM
Im looking for Terry or someone who knows what they are looking for to review my log. Thanks.
Boss86 Boss86 is offline
Car: 2007 Bmw 335i
Default E85 map question - 08-17-2018, 10:51 PM
Hey guys, I have a 2010 335i n54 fbo w/ stage 2 lpfp minus dpís. I run e52-60. Iím looking to go pretty aggressive on the tune. Mind you Iím still running the stockers. This may be a noob question, but should I go e85 or e85 hybrid on the mhd? I understand mhd e85 bef has more advanced timing, but is the hybrid map more aggressive with slightly less timing advance?
iturbo's Avatar
iturbo iturbo is offline
Car: 2009 335i e92
Default 08-28-2018, 02:42 PM
the boost levels are increased when running a BEF right? Can someone tell how much boost each map (map 1, 2, 5, & 7) produced when running back end flash?
2009 335i e92 n54 | FBO | JB4 | e85 flash |
Car: 09 335xi
Default 08-28-2018, 02:54 PM
was wondering the same thing. running e60 with a stage 2 lpfp and e85 bef on map 7 and targeting 17.5psi. do I need to set the VO to e60? when switching back to 93 do I still need to reflash to the pump bef or can I switch to map 5 and just set setting 4 from 2 to 3? thanks for the help
Roma_335i Roma_335i is offline
Default 08-28-2018, 02:56 PM
I think you need e85. E85 hybrid is for upgraided turbos.
Wrecker 426's Avatar
Wrecker 426 Wrecker 426 is offline
Default 08-28-2018, 06:30 PM
so the older files, the original ones i pulled quite some time ago apparently, said JB4_MHD_I8AOS_xxxxx, now when i download the latest the only say BB2 for I8A0S, no MHD. does this mater for I8A0S
07' 335xi, VVT Stage 2, Meth CM10, Stage 2 LPFP, JB4 Race BEF, JB4 G5, gutted stock downs, 2nd Delete, Alpina B3 Trans, JB4 Anti Lag, Phoenix Race IC, MMP AL inlets, VVT AL Outlet
prerad prerad is offline
Car: 335i E92 N54
Default 09-12-2018, 01:34 AM
Hi guys,
I have recently installed JB4 and Im currently running E85 BEF Map 7 (BEF obtained from this post).
Soon after installing JB4 I have been getting below codes:
29F4 ******* ********* Detected
29F5 ******* ********* Detected
2C7B Lambda probe behind catalytic converter 2, signal
2C7C Lambda probe behind catalytic converter 2, signal
I do have ******* *** / previously I was using COBB and these errors were not showing up...
I did a bit of research and I understand that outside USA you can use passive delete or TunerPro to code them out. Inside USA it's illegal to disable them....I'm based in Australia and I have Passive Delete enabled (see attached photo) - however errors keep coming back up....couple questions....
1. The car drives just fine - is anyone aware of any implications of these codes being triggered i.e. impact on AFR etc (given I'm running E85 current AFR logs seem little bit high 15.4 to 12.5).
2. What the best way to clear these out - any guidance on using TunerPro etc - any implications on getting these cleared out.
I have also attached one of the logs.
Cheers guys
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 09-12-2018, 08:21 AM
Originally Posted by prerad
Hi guys,
Cheers guys
As you are running e85 I guess the best for your car to load the e85 BMS flash via MHD and your car will thank you.
zcchen zcchen is offline
Car: BMW 1M
Default 09-17-2018, 07:38 PM
Any chance we can get IKM0S map in BB? Anything GOOGLE related is blocked here in China so MHD is a no-go
Default 09-17-2018, 08:07 PM
I'd have to work out the torque tables for it. Will see what I can do.
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default 2010 335 now a 2008 135? - 09-18-2018, 05:56 PM
I'm running the JB4 (BB) e85 BEF. Now when I connect my diagnostic programs (Bavarian Technic and AutoEnginuity) and select auto detect the vehicle, the programs detect a 2008 135i with a totally different VIN.
Any ideas on how to get my old car back? I imagine I could load a copy of my DME flash into TurnerPro (which I am not familiar with) and mod it to the e-85 BEF specs. but as I said, I haven't worked in TunerPro yet.
'10 E92 335 M Sport, JB-4 G5 ISO, 3" CPE Charge pipe, WMI w/dual CM 5 nozzles, 3.5 Tmap, E85 BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC. Escort Max 360
Totaled by a careless driver:
'08 E92 335, M sport option
LakerRaider LakerRaider is offline
Car: 2011 e93 335is
Default 09-18-2018, 07:44 PM
Is my 2011 335is IJE0S OR IAN0S? MHD app says IJE0S when plugged in, but I see a previous post here by Terry that says IAN0S for 335is models?
Default 09-19-2018, 09:39 AM
335is should be Ian0s.
Car: 2011 e93 335is
Default 09-19-2018, 10:04 AM
I uploaded IJE0S BEF based on what mhd said on the app... should I redo it to ina0s BEF?
edryden838 edryden838 is offline
Car: BMW Z4 sDrive 35i
Default Trouble with MHD BEF - 09-20-2018, 11:17 PM
I have a 2011 BMW Z4 sDrive 35i. I recently put on JB4 and cold air intake and so far really like the results. But then I decided to add an MHD backend flash. According to the MHD app, I have DME version INA0S, not IJE0S as I originally thought. So I flashed the BB2 pump.bin under INA0S. When done, I got an engine light, and my car was clearly messed up. It wouldn't accelerate at all. In JB4, I got code 29F3 faulty low fuel pressure sensor, except I don't think I have this sensor. I then tried the MHD pump.bin under INA0S and got the same result. I ended up flashing back to stock, and the car appears to be running normally. No more engine light and acceleration is back.
So, am I using the wrong flash? Should I be using the BEF under IJE0S since I think I have an MSD81 module? Or does no flash work with my car? I'm just confused about what might be going wrong, and I'd hate to think I wasted money on an Android device and cables and MHD license. I'd appreciate any help.
General.Massacre General.Massacre is offline
Car: 2009 E92 335i DCT
Default 09-21-2018, 03:11 AM
CHeck that you have the correct BEF setting on the JB4 set up for the car.
Go into the steering wheel controls menu, go to menu 4, make sure the the the right gauge is on setting 2.
so setting 4/2
Default 09-21-2018, 05:47 AM
I’m pretty sure it is because I tried to flash it again late last night and it was set to 4/2, still had the problem.
Default 09-21-2018, 05:52 AM
Did you set your JB4 to Map 0 before flashing?
Default 09-21-2018, 06:10 AM
Yes I did set it to map 0.
Default 09-21-2018, 10:50 AM
Itís pretty dummy proof so if it flashed then donít bother.
Car: 2011 e93 335is
Default 09-22-2018, 10:59 PM
I actually have a 2FA4 code now... I did some searching and reading and some say the wrong file was flashed? Have you heard of this?
Peshinho Peshinho is offline
Car: Bmw 335i mt n54 2007
Default 09-23-2018, 11:24 AM
Hello bro. How are you. Sent you a couple of email and a pm
Car: 2011 e93 335is
Default 09-23-2018, 10:49 PM
Flashed to ina0s BEF and 2FA4 is gone
