madoyaghi madoyaghi is offline
Car: 2007 Bmw 335i
Default new coils and plugs low boost after!! - 09-18-2018, 03:28 PM
hey all so i did a tune up for my car and there was a small water leak so we fixed the leak it was near the water pump it was a small o ring but now after everything done im only getting 5 to 6 psi the blow of valve blows out on low rpm but when i red line it its sounds like just air sucking in so loud air nose i logged it with jb4 and its only bossting up to 5.5 6 psi on map 5 the traget is 13 psi.
i check all vacum lines they all good changed them 2 month ago. turbos are new only 10k on them rebulid the wastegate there is no rattel.
Haynpunch's Avatar
Car: 07 E90 335i
Default 09-18-2018, 04:14 PM
update firmware
enable 6cyl timing logging
logs usually done in 3rd or 4th gear traction off, WOT 2k to redline
https://www.n54tech.com/forums/showthread.php?t=13114
time to do some trouble shooting....
07 E90 AT 335I 130k
JB4 G5 - Race BEF
DCI
VRSF CP - TS RP BOV-Orange Spring
VRSF V2 D-P's
7" FMIC
Stage 2 Bucket
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 09-18-2018, 04:19 PM
Did you remove or loosen any charge piping when you replaced it? Either Outlet to Intercooler pipe or maybe front turbo inlet? Maybe vacuum line to front WG got pinched or something? There is a lot of crap in close proximity in these engine bays.
Speed_addict Speed_addict is offline
Car: Bmw 335 n54
Default 09-24-2018, 05:43 PM
Happened to me once when u put back ur engine cover when u push it down am sure u pushed that silly hose behind the 6th coil check that hose if its disconnected u will lose the boost
Bmw 335 n54 jb4 iso5,n20 sensor,ER charge pipe,HKS bov,bms dci,down pipe,7 inch vrsf intercooler,backend flash stage 2 turbos ,bms oil catch can and aem lpfp.
notfrosty1 notfrosty1 is offline
Default 09-24-2018, 08:11 PM
Is your chargepipe damaged at all?
Car: 2007 Bmw 335i
Default 09-26-2018, 06:21 PM
I have to check that could be that i never checked it and my cover goes in kinda forced so ya could be that i have to check tomorrow where that hose located exactly?
Haynpunch's Avatar
Car: 07 E90 335i
Default 09-26-2018, 08:54 PM
What kind of charge pipe do you have? OEM plastic?
07 E90 AT 335I 130k
JB4 G5 - Race BEF
DCI
VRSF V2 D-P's
7" FMIC
Stage 2 Bucket
Car: 2007 Bmw 335i
Default 09-26-2018, 08:56 PM
I got the hks
https://www.1addicts.com/forums/showthread.php?t=846715
i updated jb4 got 2 codes not sure if it has anything todo with my problem
2ABC
3100
Car: 2007 Bmw 335i
Default 09-27-2018, 08:09 AM
She’s throwing all kinda code today was throttle body when I removed the code car started ideling up and down then turned off so i rest the throttle body manually holding down the gas pedal for 5 seconds, then it worked but with codes again p0221...
Not sure what is wrong with this car...any ideas?
Default 09-27-2018, 09:38 AM
Originally Posted by madoyaghi
Sheís throwing all kinda code today was throttle body when I removed the code car started ideling up and down then turned off so i rest the throttle body manually holding down the gas pedal for 5 seconds, then it worked but with codes again p0221...
Description of code plz?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2007 Bmw 335i
Default 09-27-2018, 11:39 AM
they are all throttle body related senor and the TB is new changed 2 moth ago
Default 09-29-2018, 11:22 AM
Are u sure you did the TB reset correctly- thereís a specific procedure
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2007 Bmw 335i
Default 09-29-2018, 01:22 PM
my mechanic did it on his scanner
Default 09-30-2018, 11:20 AM
You can reset TB via MHD- just follow the specific procedure outlined in the instructions. If you donít follow car will act funny / run like ass
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2007 Bmw 335i
Default 10-01-2018, 10:15 AM
W did that when we got the new TB worked perfect but this started happening after we did the water leak job and the new coils and plugs , my mechanic is saying he probably forgot to plug in something when he was putting it together but when i drive it like that and i give it gave you can hear like air getting sucksd in louddd really loud and boost doesnít go over 5.5 psi blow off valv blows off on low rpm not on high rpms . I plugged it in today and got 2 codes car is in limb mode .
Codes
Throtel valve potentiometer 1 , plausibility, air mas
Throtel valve potentiometer 2 , plausibility, air mas
