Peshinho Peshinho is offline
Car: Bmw 335i mt n54 2007
Default Thanks thanks and more thanks to Payam - 09-13-2018, 02:50 PM
I want to say thank you to Payam. He is not only very knowledgeable person but also very kind.
I am from Argentina. This is the car i own.
335i mt 2007
Here you have the car components.
Map 3.5 bar
Clutch Spec stage 3+
Mfactory single mass flywheel
Pure turbos stage 2+ high flow 2" output with ceramic coating
********* vrsf 3"
Exhaust custom mande in aluminum
Qtp cutouts in 3.5"
Catback Magnaflow
Intake Afe with scoops
brembo big brakes stage 5
Manifold Evolution of speed
Fueling Stage 4 de fuel it with flex fuel
Injectors dw de 1000cc
Jb4 with bt
Mhd k-dcan cable
Payam helped me more that 20 times to get the car every time faster. A actually I am using e70. Not sure abouth hoy many whp i have but I guess around 600/650 to the wheels with 29 psi.
Payam had a lot of Patience with me. Being im argentina is very difficult to get help from the us. So I am very grateful with Payam.
Kudos to you bro. Payam never change !!!
Default 09-13-2018, 04:09 PM
Ahh thank you so much man. I really appreciate the time you took to write this.
Keep the logs and videos coming. I'll be around to check it out
Default 09-13-2018, 04:14 PM
You can count on logs and videos. I really appreciate your help.
Thanks and more thanks
emiliano1's Avatar
emiliano1 emiliano1 is offline
Car: 135 N54
Default 09-18-2018, 09:48 AM
Payam also helped me to solve the missfire problem.
If it were not for your help, I would still be looking for the problem.
09 135 jb4 g5 ISO-pure turbos stage 2-fuel it port meth injection-MHD Race Flash-BMS *********-Active Autowerke 6' fmic-forge diverter valves-n20 tmap-RB inlets-afe stage 2 air filters-CP e charge pipe-Berk street exhaust
Default 09-18-2018, 12:02 PM
Ahh I remember! Yes, that misfire is very annoying and glad it was a simple fix. Thank you man, I am truly happy to help you all.
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 09-18-2018, 12:08 PM
Go PAYAM!
Torgus Torgus is offline
Car: 335xi
Default 09-28-2018, 04:29 PM
payam is the man /thread
Got Boost?
Default 09-28-2018, 04:57 PM
Without doubts. He is the chosen one ')
