notfrosty1 notfrosty1 is offline
Default Shredding belts? - 09-05-2018, 04:04 PM
I just finished putting in a new belt and tensioner on my n54 while I was in there I checked all the pulleys, pulled my main crank pulley, and cleaned out debris behind it, put everything back together and started the car, sounded great for about 2 mins before the belt started shredding again, I immediately turned off my engine and now I donít know whatís causing it. Any ideas of what to check? Iím pretty upset because this car has been out of commission for 2 weeks now. Thanks
Car: 09 E90 335i Msport
Default 09-05-2018, 04:06 PM
Check the clutch type pulley on the alternator and the PS pulley for any cracks or missing spots, double check your belt routine too.
Default 09-05-2018, 06:09 PM
Ive inspected the pulleys and they all look fine, but would a small crack really shred my belts that quickly? im talking about less than 5 minutes here. if so, ill pull it all out and check again but i cant believe that a small crack in a pulley would ruin a brand new belt
Default 09-05-2018, 06:18 PM
Yes it would if it's throwing the balance. Did you check if the alternator pulley isn't seized?
Default 09-05-2018, 07:18 PM
the pulley seems fine, while i was replacing the belt, I noticed my AC pulley was BEYOND loose, i could unscrew the bolts with my bare hands no problem, so i snugged those up and threw the belt on. I have no clue what could be causing them to shred but i will double check
Default 09-05-2018, 07:26 PM
Make sure you check the alternator one.. it's a clutch type and it caused me a lot of headache.. no shop could figure out my belt shredding problem.
parksjm7 parksjm7 is offline
Car: 335i 2007 coupe sport
Default 09-06-2018, 07:45 AM
A big chunk of my plastic Power Steering pulley facing the engine was missing - I could not see it until I replaced it.
suspenceful's Avatar
Car: 2008 BSM 135i
Default 09-06-2018, 08:49 AM
My issue and fix: http://my1series.com/2015/03/23/bmw-...e-belt-issues/
I dealt with this headache for too long as well.
2008 BMW 135i 6MT - Doc Race Single Turbo 6266
752whp/691wtq @ 30psi, weighs 3260lbs
Complete build info: my1series.com
YouTube channel: youtube.com/jakespence135
Instagram updates: instagram.com/jakespence
N54 t-shirts, etc: bimmerstreet.com
dyezak dyezak is offline
Default 09-06-2018, 10:58 AM
You need to drop your oil pan and remove all the belt pieces from the pan and the oil pickup tube now.
Car: 335i, 2009
Default 09-06-2018, 11:45 AM
Excellent write up in that thread relating to the belt
335i E90 2009 ///M Sport Auto
Mods: | Wagner Intercooler | MeowPipe | Meth-Trunk | JB4 | Pump_Back_End_Flash | Fuel-it! Stage 2
Drivetrain--------ForgeStar F14 Wheels 18" (245 & 275 PS4) | XHP L3 Transmission Flash | Wavetrac LSD
Suspension-------KW V3 Coil Overs| M3 RSF Bushings and Dif Bushings | H&R Sways
X5 50i 2013 ///M Sport
BMS Stage 1
Default 09-06-2018, 02:31 PM
From what I’m getting from everyone, I should just replace all my pulleys, drop the oil pan, pull the main seal and hope for the best? That just seems like a sh!tload if work for a 2 minute problem, not to mention $$$ but I will be taking it apart today so we’ll see how this goes
Default 09-07-2018, 03:15 PM
Update:I was inspecting the pulleys and the alternator pulley is cracked/chipped in more than 1 place as well as the power steering pulley, do you guys think this is what would be causing it?
Default 09-08-2018, 03:00 PM
Got into the belts, everything was good except the alternator pulley. Seized both ways, thank you so much for the insight Iím off to get a new one RN
