Nebula19 Nebula19 is offline
Car: Veloster N
Default Fuel Wire for 2.0L - 09-24-2020, 07:12 PM
Hey guys, I know which wire I need to connect to on the O2 sensor side but my jb4 didnít come prewired with the fuel wire. Which pin does the fuel wire connect to on the jb4? Also,does it need the resistor?
Car: 2020 Kia Forte GT
Default 09-26-2020, 05:25 AM
Where did you get your JB4 from?
The Hyundai/Kia use the same JB4 SKU
Two connectors, OBD-II connector and two wires. The short black wire is not currently used, the long black wire is for the o2 sensor.
Why would need a resistor?
As usual this post is useless without pictures, tech support can't help you without pictures.
Car: Veloster N
Default 09-26-2020, 07:05 AM
My bad let me be specific. The wire Iím trying to connect to my jb4 is the fuel tap wire. For the Kia 3.3t the fuel wire connects to both o2 sensors to control the fuel ratio. Since the 2.0L only has one o2 sensor I needed to know if the tap wire Follows back to port 21 or 20 on the jb4. The resistor was mentioned in a forum I believe itís on the short wire.
I purchased my jb4 used so there is no short and long wires. Only the two pigtails that go to the two sensors on the intake side. Iím assuming according to what you are saying that I need to run my wire back to the port where your long wire goes on your jb4. Which port is the long one going to? 20 or 21?
Default 09-26-2020, 11:40 AM
I don't remember which port is on the connector sorry and I just had my JB4 out of the car.
Email tech support Ando or Terry do reply on weekends.
Default 09-26-2020, 11:47 AM
You only need to attach the longer wire for the 2L. See the fuel control wire install video for what position that long wire attaches to. Not at my desk to check.
Car: Veloster N
Default 09-26-2020, 12:07 PM
Does the long wire need the 1k resistor?
Thanks Terry!
Default 09-26-2020, 01:15 PM
Thanks Terry!
No as long as it's in the right spot on the JB4 harness, the board has a resistor on that output already.
Car: Veloster N
Default 09-26-2020, 01:45 PM
I put it in 20, anything I need to do or is my jb4 going to already adjust my afr? I made sure to update firmware.
1st timer's Avatar
1st timer 1st timer is offline
Car: 2015 Kia Optima turbo
Default 10-01-2020, 12:00 PM
Jb4 will lean it out a bit. Without fuel wire I was at 10.6 afr and with it on I'm at 11.4 11.7
2015 Kia Optima SX-T
Mods: ultimate racing strut bar, JB4 set at map3, HKS
M40XL plugs, cpe bellmouth, injen intake ,Forge BOV, catch can. Continental extreme contact DWS tires
