Lil Ripper's Avatar
Lil Ripper Lil Ripper is offline
Car: 2019 Veloster turbo
Default Map 5 wmi log Check please - 09-03-2020, 07:45 PM
94 octane with WMI on. AFR is a little leaner than normal? I thought Ignition timing looked ok. I am trying too source e85 here in Alberta. Or would i be better off injecting straight 100% methanol, forget the water.
Default 09-04-2020, 12:21 PM
Seems OK to me here. On the WMI mix it doesn't matter much, usually 80% meth 20% water is a good "aggressive" mix.
Lil Ripper's Avatar
Default 09-04-2020, 07:28 PM
Sounds good, I am more like 60m/40w now. I have my meth kit mounted behind the bumper, so I'm not too worried about having flammable liquid in my trunk. I am using my washer fluid tank instead of the 1 gallon BMS tank I ordered.
