(#101)
Audisom Audisom is offline
Car: 2013 S6
Default 09-06-2019, 01:33 PM
So,
1 = 3psi added over stock
2 = 2psi added over stock
3 = 1psi added over stock
4 = 0psi added over stock?
Default 09-06-2019, 01:55 PM
Originally Posted by Audisom
So,
correct.
2021 VW Golf 8 R
Default 09-07-2019, 12:12 PM
So map 2 is 5psi over stock right.
0 = 5psi added per base map2 or essentially disabled
1 = 3psi added
2 = 2psi added
3 = 1psi added
4 = 0psi added
Is this look right?
So you can’t request 4?
I am confused
Sorry quoted the wrong post earlier.
0 will disable the feature.
1 cuts 1psi so total 4
2 cuts 2psi so total 3
3 cuts 3psi so total 2 etc.
So lets say if you using a map 6 with peak of 6 and want to extra boost in 1st you set it to 6.
2021 VW Golf 8 R
Chio4 Chio4 is offline
Car: S6
Default 09-17-2019, 12:30 PM
I have noticed running map 2 93 oct that if I am going about 45-50 MPH and hit there is A delay and almost like it bogs down. anyone else notice this? I have not run logs on this yet
Default 09-17-2019, 02:36 PM
Can you test if it does this in map 1 as well.
2021 VW Golf 8 R
Car: S6
Default 09-17-2019, 07:26 PM
I will log both map 1 and 2 for you
chrislakt chrislakt is offline
Car: 2016 Audi S6
Default 09-26-2019, 04:40 AM
Installed mine today with out a hitch, all i can say i wow.
The car feels so much stronger compared to stock. I owned the car since new and the JB4 has completely transformed it into a beast.
I'm in Australia, so we are right hand drive and had to install the JB4 between the positive terminal and the intake, it secured well and all the cable lengths reached fine.
I was previously using another piggy back type though the JB4 smashed it out of the ball park, i'm not sure what it was doing though JB4 map 1 is much much stronger.
I've emailed through some logs so i'd be interested to hear your feedback.
2020 M550ix
Sold 2016 Audi S6
Sydney Aus
Default 09-26-2019, 05:32 AM
Happy you satisfied. How did you route the OBD cable?
2021 VW Golf 8 R
Car: 2016 Audi S6
Default 09-26-2019, 06:14 AM
The easy way via the door, when I have more time Iíll look for way to run the OBD cable through the firewall.
2020 M550ix
Sold 2016 Audi S6
Sydney Aus
Car: 2013 S6
Default 10-13-2019, 07:11 AM
Is there a update in the works?
Default 10-14-2019, 05:32 AM
We working on a few cars that run higher octane fuel fitting our boost control module. The barrier with this is going to be fitment as the radiator needs to be leaned forward and cars with distance control wont be able to do this unless they go through major effort for the install.
2021 VW Golf 8 R
Dirt Dirt is offline
Car: S6
Default 11-13-2019, 06:01 AM
How is everyone securing the JB4 in the engine bay? I'm looking for a simple, clean way of keeping the JB4 from bouncing around.
esemes esemes is offline
Car: 2016 S6
Lightbulb 11-16-2019, 05:48 PM
in the same boat here. any advice??
Default 11-16-2019, 06:20 PM
zip tie it!
NewYorkS6's Avatar
NewYorkS6 NewYorkS6 is offline
Car: 2018 Audi S6
Default 12-12-2019, 02:53 PM
BETA Install Guide Here: http://www.burgertuning.com/instruct...sis6_guide.pdf
not working anymore. new link?
Default 12-12-2019, 02:56 PM
Try this https://www.n54tech.com/instructions...sis6_guide.pdf
2021 VW Golf 8 R
NewYorkS6's Avatar
Car: 2018 Audi S6
Default 12-12-2019, 03:00 PM
thats the one i was looking for. thanks. top link is broken
NewYorkS6's Avatar
Car: 2018 Audi S6
Default 12-12-2019, 03:06 PM
also for those still looking, may be able to pass straightened wire coat hanger with slight curve to it through footwell deadpedal gromet into engine bay. pull plastic cover in engine bay and try to locate coat hanger peeking through. two person job, or else remove washer reservoir and ecu to find coat hanger. not too difficult and cleaner than door jamb route.
Default 01-02-2020, 04:15 PM
Some photos would be great! We're still rocking the door jamb method on our S6.
335i 335i is offline
Member
Default 01-25-2020, 11:41 AM
I ran a 7.46@93.7 in the 1/8th mile last night with this on my A8L limo (map 1) plus silly rabbit intakes. I think that would be around an 11.5@119 in the 1/4. 1.72 60ft, 93 pump, and negative DA. Awesome product.
Default 01-25-2020, 06:53 PM
Nice going.
2021 VW Golf 8 R
Blampnw2016 Blampnw2016 is offline
Car: Audi s6
Default 02-20-2020, 10:26 PM
Just got my JB4 installed on my 2017 s6. I don’t see the oil temp or Tran temp gauges work. Is this expected? Using the Bluetooth connection and android app.
Default 02-21-2020, 10:31 AM
Yes, some gauges are still under development. As we add them we'll update the thread with firmware to load.
Member
Default 02-27-2020, 10:33 PM
Any success with stacking the JB4 with a traditional ECU tune?
Iím thinking of installing RS7 turbos with +4mm hybrid compressors. There is an ECU tune for the normal RS7 turbos, but not the hybrids. I wonder if the EGT temps and knock would stay low enough to ask for a few more PSI on the same fuel (93 octane) using the JB4.
2014 A8L 4.0T.
Default 02-28-2020, 12:08 PM
Yes we have a few customers using the JB4 on top of their S6 for fine tuning, reducing boost at the launch, etc.
