(#3626)
alo0oy215's Avatar
alo0oy215 alo0oy215 is offline
Car: 2012 f30 335i
Default 12-12-2018, 12:53 AM
Will the new integrated firmware work with a BEF? And what should i do? Only solder the diode and load the firmware?!
N55 powerd 335I sedan :
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
5- BMS F30 N55 Performance Intake
6- BMS WMI KIT
Bsbllfit7 Bsbllfit7 is offline
Car: 2013 535i
Default 12-17-2018, 04:42 PM
Is it recommended to go with the integrated Version 12 t2 or should we be going to ISO and cut the diode?
tomerz tomerz is offline
Car: 2014 m235i
Default explanation - 12-21-2018, 12:08 AM
Hello everyone where can i find a detailed explanation for the JB4-APP
Car: 2014 m235i
Default ??? - 12-23-2018, 03:10 AM
rallyrafa rallyrafa is offline
Car: 535i GT 2011
Default 6-cyl timing - 12-23-2018, 08:53 PM
@terry
Can we have the ISO function of "6-cyl timing logging" to be "gas pedal aggressiveness" too? Or it's already in the integrated?
Or it's exclusive of ISO?
2011 535i f07 custom pipe after turbo, VRSF CP, K&N CAI, E40+ BEF
Default 12-23-2018, 10:18 PM
For PWG, 12_T2.
Default 12-23-2018, 10:19 PM
Originally Posted by rallyrafa
@terry
Pedal aggressiveness is menu10 in dash with PWG_12, 0-5000 = 0 - 100%
Car: 535i GT 2011
Default 12-24-2018, 07:07 AM
@terry
What is menu9?
Cant find anywhere
Marlinman's Avatar
Car: 335i coupe 2010
Default 12-24-2018, 08:31 AM
@terry
What is menu9?
Cant find anywhere
Read some of the forum sticky threads, watch videos, etc. it is all in there.
Default 12-24-2018, 10:05 AM
@terry
What is menu9?
Cant find anywhere
Base dutycycle but isn't used on PWG_INT.
zookerjr5 zookerjr5 is offline
Car: 2012 335i F30
Default 12-28-2018, 10:50 AM
I downloaded and updated to the new PWG_T2 and not much is lining up. The OBDII menu does not match what is listed. For example the menu with boost on fuel gauge and AFR on speedo only has two options not 4.
Will this be updated?
sabujan sabujan is offline
Car: 335i f30 2012
Default 12-29-2018, 01:28 AM
Hi Terry -on my car N55_F_PWG_INT_12 - menu10 when set to any value above 0 - through in dash shows transmission error - with 0 no issues
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 01-02-2019, 10:58 AM
Terry I tried firmware JB4_F_EWG_16_TEST5 on my big turbo setup and it did not run well. I also noticed any time I let off the gas or was at a complete stop the target boost was always 14.2psi.
Ldenne123's Avatar
Ldenne123 Ldenne123 is offline
Car: M135i 2014 EWG JB4 MAP 2 + MHD BEF *****
Default 01-05-2019, 06:06 PM
Hi there I am booked in for a rolling road i was wondering do they need to use the obd for this as the obd port is used already for the jb4 , as I understand if I disconnect this will disable my map and won't have the power for the dyno ?
Thanks ..
Car: 535i GT 2011
Default 01-06-2019, 10:52 AM
@Terry
Hi terry, i'm achieving sucessfully content of e42, can i try e50 or more?
The Log show the pump working the same with e42 and e25(Our fuel here starts with e25).
To start with e50 should i change the BEF to E85 mix or can i stick with RACE BEF?
kinetic kinetic is offline
Car: M135i
Default 01-18-2019, 04:26 PM
After the last firmware update, on mi M135 PWG
The Trans Temp Gauge on the mobile App (Android) stopped working..
it shows "-17". Everything else is working properly..
TwistedX TwistedX is offline
Car: 2015 BMW X6 35i
Default 01-18-2019, 09:54 PM
The Trans Temp Gauge on the mobile App (Android) stop working, it shows - 17 everything else is working properly.. Attachment 82849
You try disconnecting and reconnecring?
Project Succubus - 2015 Estoril Blue M235i F23
Sponsors: SoloWerks, Extreme PowerHouse, and AEM Intake Systems
Car: M135i
Default 01-19-2019, 10:01 AM
I tried that before making that post, and I mean the obd connection, the car and the Bluetooth connection
Mannypr24 Mannypr24 is offline
Car: Bmw 335
Default Drivetrain Malfunction - 01-19-2019, 11:22 AM
Hi, I am on the Iso Firmware.
Having this codes- 120308- Boost pressure lower than expected
And 108F01. What can cause this issues?
Also running mafless.
2013 N55 F30- PWG, JB4 ISO_11, CP, MEOW LESS PIPE, FMIC, STOCK TURBO, STOCK INTAKE. 93OCT.
Phataxe's Avatar
Phataxe Phataxe is offline
Car: 2014 435I
Default 01-19-2019, 11:27 AM
Wrong area and need to post a log if you wanna get any kinda real advice bud. Try to post in the Support area with a log
'14 435I RWD MHD "Shoup Custom Tune" BigBoost Stage 3 Turbo Spool FX-150 XHP Trans Tune VRSF Race Cooler VRSF CP BMS Intake Borla ATAK Exhaust Custom Down-pipe Stage 3 LPFP BMP4 EKP M Performance LSD Phoenix Racing PI Intake Manifold AIC2-P controller e85 3.5 TMAP NGK 5992 Plugs "0.020"
Car: 2012 335i F30
Default 01-21-2019, 07:20 AM
Attachment 82849
I have the same problem my trans temp does not work anymore either.
Car: M135i
Default 01-21-2019, 08:10 AM
im starting to think that the problem is the app update, and not the firmware update..
Car: 535i GT 2011
Default 01-21-2019, 06:22 PM
@terry
There will be a new firmware/BEF update for the new released xHP flash tool that supports the new zf8hp?
Or no need for it?
135idct 135idct is offline
Default 02-01-2019, 09:21 AM
is ur boost on target when u go WOT? in this firmware?
i run same ur setup EFR8374
liuchen333 liuchen333 is offline
Car: m135i pwg
Default 02-14-2019, 07:55 PM
Hello, brother. I have the same problem. how did you solve it?
