(#901)
NEVERENOUGH's Avatar
NEVERENOUGH NEVERENOUGH is offline
Car: 2014 650i Gran Coupe M sport
Default 12-10-2018, 03:43 PM
Any chance of BEF for S63tu?
lazyninja87 lazyninja87 is offline
Car: 2012 F30 335i
Default 01-10-2019, 12:20 PM
If you're happy with how it runs keep on rolling. A lot of guys were not happy with the F PWG ISO programming, so we've improved the F PWG integrated firmware to accomidate.
You can solder another diode on (it's a generic 50v diode), upgrade to a V2 board at a discount, or send that board in and we'll solder it back for you, as need be. If using a V1 board still good opportunity to move up to V2.
Whats the difference between the V1 and V2 boards?
rallyrafa rallyrafa is offline
Car: 535i GT 2011
Default 01-12-2019, 12:42 PM
@terry
What are the target boost for map 1 and map2? I'm using map 7 and It targets 18.5 psi
2011 535i f07 custom pipe after turbo, VRSF CP, K&N CAI, E40+ BEF
steezyN55 steezyN55 is offline
Car: 2015 335i
Default F30 n55 BEF issues - 01-12-2019, 01:13 PM
I am currently running the jb4 and I am trying to put a back end flash I purchased the bimmergeeks cable with the cable to connect to the tablet I just purchased off amazon. I downloaded the MHD app and I unplugged my cable for the jb4 and plugged in the bimmergeeks cable that I got off their website and then opened up the MHD app and plugged the cable into the tablet, clicked on MHD license store so I can purchase a license but it just keep saying it cannot connect to dme. Iíve tried it multiple different ways. I have the switch on the cable all the way to the right Iíve tried it all on the different switches I have my ignition on Iím not sure what I am doing wrong or what else to do.
ConR 37 ConR 37 is offline
Car: M135i
Default Adding BEF to JB4 - 01-31-2019, 09:23 AM
Hello Everyone,
First post here, I've read through most of this thread but have a couple of questions which I would be grateful for your support.
At the moment I have an EWG M135i with a JB4, have the additional TMAP3.5 Sensor and a custom Map 6 tune. Only bolt on is a Sports *** and the dyno print out shows 406bhp.
I have been running this setup for over 12 months now and would like the idea of adding a MHD BEF to improve the power delivery as traction is a bit of an issue.
My questions are:
1- I am based in the UK and don't plan on using methanol so the best fuel rating I can use is 99RON (93OCT Equivalent) Which BEF map would be best for me?
2 - Do I need to alter any additional settings with having the TMAP sensor?
3 - This may sound obvious, but to install the BEF I unplug my JB4 from my cars OBD and then plugin the KDCAN cable in to the OBD. I am just unsure how the JB4 interacts with the MHD if not plugged in to the OBD?
For now I think that's everything.. I'd just like to make sure I fully understand the requirements before I look to move any further.
TIA
Default 01-31-2019, 09:25 PM
1) The standard RACE file, then log and we can evaluate.
2) No the JB4 continues to handle all MAP sensor voltage conversions.
3) After loading you plug back in the JB4.
Car: M135i
Default 02-01-2019, 02:39 AM
Thanks Terry.
Just need to get myself all of the equipment needed then.
Presumably I would use the data logs from the JB4 and send them over? I haven't logged myself previously, but I do have the data cable and a laptop.
Any tips for logging?
TIA
Marlinman's Avatar
Car: 335i coupe 2010
Default 02-01-2019, 05:43 PM
Stability control off. Log in from 2.5K to 6K. I use fourth gear but I'm sure you could do Fifth or even third. Terry likes it too if you row through the gears! (safely)
Default 02-01-2019, 06:24 PM
Originally Posted by ConR 37
Thanks Terry.
TIA
Yes data cable is great if on a budget, but if you're a high roller the JB4 mobile adapter to log to your phone is the way to go.
TwistedX TwistedX is offline
Car: 2015 BMW X6 35i
Default 02-04-2019, 06:41 AM
Is there any BEF Map updates?
Project Succubus - 2015 Estoril Blue M235i F23
Sponsors: SoloWerks, Extreme PowerHouse, and AEM Intake Systems
Default 02-04-2019, 10:47 AM
We're always working on things but the latest public maps are in the first post.
Default 02-05-2019, 04:03 PM
Was just curious as they are from 8/18
Ldenne123's Avatar
Ldenne123 Ldenne123 is offline
Car: M135i 2014 EWG JB4 MAP 2 + MHD BEF *****
Default 02-11-2019, 04:55 AM
Hello Everyone,
My questions are:
TIA
Hi I'm a bit confused here a as I have same mods as urself and asked the same questio was told to use the PUMP flsh not the RACE as I was only using pump fuel (shell v power 99 ron in the UK) should i be on the RACE BEF ?...
Mr_m235i Mr_m235i is offline
Car: m235i
Default 02-11-2019, 06:01 PM
Can we use the MHD app while running the JB4 BEF for monitoring or logging and how? cause I dont have the JB4 bluetooth.
Marlinman's Avatar
Default 02-12-2019, 04:09 AM
Terry where do you recommend we post logs now that you have the integrated PWG firmware back on board. (also for those equipped with BEFs)
Default 02-12-2019, 09:47 AM
Get the data cable or bluetooth for JB4 datalogging.
Post in the support section.
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 02-13-2019, 10:33 AM
I was wondering the same thing on the BEF updates.
2013 BMW 335xi F30 N55 PWG
Marlinman's Avatar
Default 02-25-2019, 08:00 PM
BMS, can you guys support modifying the BEF for those of us that want to go the upgraded TTFS HPFP route? Allegedly the flash tune needs to be changed, etc. or the car won't even start!
neejay's Avatar
neejay neejay is offline
Car: 2011 535i M-Sport
Default 02-28-2019, 11:44 AM
I got an update from the Play Store:
Code:
WHAT'S NEW
♦ v1.11 ♦
- Added on N55 an xHP setting (transmission choice page) for OTS maps.
- Added on N55 a linear throttle (flash option).
- XDI pumps support (flash option).
- N55 EWG maps v1.08: fixed boost target drops when targt rail pressure is changing.
- Added some default min/max values for common log channels.
- Minor bugfixes.
EDIT: I just realized I'm not sure if you modify the MHD files for JB4 owners, or if you provide your own files from scratch.
2011 535i M-Sport - MHD Stage 2+ BEF w/ JB4 (logging), xHP Stage 3, BMS Intake, FMIC, ER Chargepipe, RM Motors catted d/p, Megan Racing Supremo Exhaust
Car: guess...
Default 03-01-2019, 07:52 AM
MHD app said I need a one-time bench flash to unlock my late model DME. I can have it out in 15 minutes. Once out and boxed, what address do I send it for flashing. I tried contacting ***** but emails have stalled.
Marlinman's Avatar
Default 03-05-2019, 02:10 PM
Terry,
Would there be a reason not to use RACE with 93 fuel?
My timing on Cyl 5 and 6 stays at 0 throughout the pull, I'm confused as to whether this is considered a "timing drop" or if timing drop is delta throughout the run say from 10 to 6. I always thought it was the latter.
Estoril_AJ Estoril_AJ is offline
Car: F30 335i
Default 03-10-2019, 03:15 PM
Curious if you have an update, as I would like to do an xHP flash to my transmission. I have heard there are issues with a custom flash through MHD (your BEF) and the xHP flash. Please advise what I should do? The current map is 8/18, well before the xHP release
Thanks again for all of your help and time spent on this!
_____________________________________________
2014 335i xDrive | aFe Intake | Dinan Exhaust | E85 Mix |
MHD + JB4 BEF {Map 2,6,7} [EWG_E85_10} (8/2/2018 MHD Map)
neejay's Avatar
Default 03-10-2019, 03:18 PM
I didn't have any issues flashing xHP, granted I'm in a F10 n55 8-spd. What issues are you hearing about?
Car: F30 335i
Default 03-13-2019, 08:44 PM
A couple people on the MHD group on Facebook were mentioning an issue with custom tunes and xHP. However, if you are saying you did not experience these issues, maybe the BEF is ok? I have an F30 N55 8Speed EWG, so we have very similar cars.
I am strongly considering this upgrade, any feedback? I have yet to speak to someone that has both JB4 BEF MHD and xHP on our N55
spammer's Avatar
spammer spammer is offline
Car: 435i
Default 03-27-2019, 02:45 PM
I've been reading this thread since the start, and finally...
I ordered my Nexus 7 and Burgers cable. Ill be flashing this weekend w/ the race flash.
FBO 435i with 40% E85.
Any tips / tricks/ hiccups i should be made aware of that some of you may of learned along the way?
Hows everyone liking it so far on the F N55?
How are the burbles?
What are the new (if any) boost targets for map1,2,5,7?
