decobm decobm is offline
Car: f10
Default Log review 435i pureturbo + fbo + methanol - 11-13-2020, 07:45 AM
Afr and psi I think not good
435gc 435gc is offline
Default 12-13-2020, 01:08 PM
Yeah not good.
You are getting timing and throttle cuts. Afr gets too lean. IATs are also way up there. Generally would not want to see them climb like that especially since you are using wmi.
Strange you are not getting kicked to safety map as you are overboosting past the boost safety limit.
I would back off the meth adder. 90 is too high until you get things straightened out. I'd go down to 50 and relog. Only increase gradually as your logs permit.
What water meth ratio are you running?
What fuel?
What size intercooler?
Also relog 3rd gear 2k to redline, shift to 4th stay in 4th 2secs then stop.
