TeeRoid TeeRoid is offline
Tee-Roid
Car: 2009 535i
Default AEM 320 DIY for 2009 535? - 01-02-2014, 09:51 PM
Can somebody direct me to a AEM 320 DIY for the 2009 535? Ive been looking around but hadn't seen 535 specific. Also is the AEM 320 a direct replacement or will modifications have to be done? Also is there a special tool needed or not necessary?
Default 01-03-2014, 03:10 PM
You need a 2 ft length of 5/16 Gates submersible fuel hose and a pair of fuel hose clamps (rounded edges so they don't cut the line). A few zip ties.
I don't have time to write up a full DIY, but basically you will be swapping out the stock LPFP with the AEM 320. Get the 320-E which is ethanol specific. It's a dark green color, AEM 50-1200. There's a cheaper black pump, AEM 50-1000. I'd go with the green one since we are running high ethanol mixes. $120 at Summit Racing.
Run the tank down to 1/4 or less, this way there will be les fuel to deal with. Disconnect the battery negative cable in the trunk.
Pull the rear seat off. Tug at the front edges and it pops free. Then unscrew both lids on each side. You can tap them loose by using a large bolt or something with a flat surface. A screw driver is a bad idea as it might break off the tabs on the metal collar holding the fuel bucket.
Disconnect the hoses on the left/driver side. This is so you can pull the hoses across and get access on the right/passenger side.
Notice the discharge hose coming out of the top of the pump. You need to remove that and the pump. It is heat shrunk onto the pump and the white connector in the middle saddle part in the tank. You can't disconnect it without pulling all the hoses across, that is why both buckets have to come out.
Connect the new Gates hose with your fuel clamp to the white connector in the saddle. Then swap out the oem pump in the bucket. Add a short piece of rubber hose to the bottom of the AEM pump per picture below. Use oem filter in the bottom of the bucket. Secure locking clips with ties. Close up the bucket and lid. Connect wires.
Be careful not to wrap the fuel hoses on the outside of the flipper arms (for fuel gauge). They need to be able to move to horizontal with no restriction. There is one in each side of the tank, connected to each bucket.
Hope this helps, here are some pics courtesy of Skysurfer.
Tee-Roid
Car: 2009 535i
Default 01-03-2014, 03:59 PM
Ok great, thanks Ocean. I will get the pump on order and make this my next project...My only reason for this upgrade is because car is bucking and fuel pressure drops to 54lbs around 5500rpm..i do not have e85 in my area, but I will purchase the green pump, for future
Default 01-03-2014, 04:15 PM
The AEM pump is rated 340 LPH. The stock VDO pump is rated 175 LPH.
There's no downside to making this swap, except it can be a PITA to open up the buckets and get access.
Very strange that you would see 54 LBS on pump gas. You are OK above 50, but quite surprising. Is it just a short dip or a sustained pattern where it drops and stays there? Sporadic dips don't really matter, it's about the pumps ability to produce sustained pressure as it is feeding the HPFP.
Tee-Roid
Car: 2009 535i
Default 01-03-2014, 05:10 PM
My fuel pressure is consistent below 4k rpm -67-70lbs, and then from 4k -6k-4k rpm its all over the place, plus it bucks. Well I looked on my log at the rpm the graph shows where it bucks, is where the fuel pressure dives to 50-54lbs. If I knew how to post a log I would.
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 01-03-2014, 07:01 PM
To post jpg or csv files:
1. Scroll down to the "Manage Attachments" button near the bottom of the page and press it.
2. A Pop Up window will appear. If the file you want to load is on your computer press any "Browse" button.
3. Find and select the file you want to transfer from your computer and press the "Open" button.
The path name will automatically fill in.
4. Repeat 3 if loading more than one file by selecting another "Browse" button.
5. When all the files you want to transfer are defined, press the "Upload" button.
6. Scroll down to the middle of the Pop Up window to see the files that were transferred.
Incorrect files can be removed by selecting the file and hitting the "Remove Button".
Note: Not all file types/sizes can be transferred.
Scroll down to the bottom of the Pop Up window for the type and size limits on files to be transferred.
Remember to post logs only in the Help Section when Help is needed.
Tee-Roid
Car: 2009 535i
Default 01-03-2014, 07:11 PM
...Thanks
