nelsonmg nelsonmg is offline
Default basics for e85 - 05-07-2013, 02:46 PM
can someone please explain the basics of running e85.
i have intercooler, *********, intake, jb4 g5iso. do i need anything else? any prep-work or post-work?
can i just dump certain% of e85 into take and i am ready to roll? if so, what percentage is good starting point?
thanks in advance.
2009 335i e90 n54; sport; premium; logic7
v8bait's Avatar
v8bait v8bait is offline
Car: E92 335i 6MT
Default 05-07-2013, 02:53 PM
What you need for E85:
1) JB4
2) E85 gas station
3) Datalogs
4) ???
Start with say 30% or so. I dunno, maybe put in 4 gallons to a full tank. Do some runs in map 5, try to avoid brown pants, post logs and CSV's here. If everything is kosher, go to 50% E85, maybe like 6-7 gallons to a full tank. Do some runs in map 5, try to avoid getting sexually excited with the windows down, post logs and CSV's here. FBO with 50/50, you may need the LPFP upgrade (that would be 4 and the ???'s). That's what the logs will tell you.
Ohh, and
5) Profit.
justohigh justohigh is offline
Car: 2007 335i coupe
Default 05-07-2013, 02:57 PM
thanks in advance.
You have everything you need to run 50% and lower of E85. It's suggested to start off with 30% E85, since every car is different and reacts differently to E85. If that works out, then increase to 40% and then 50%. Make sure to put it on map 5 and do your 3 3rd gear pulls for it to auto tune. Buckle up The power increase is like when you just put the JB4 on your stock 335.
Default 05-07-2013, 03:31 PM
thanks gentlemen.
Fishsticks's Avatar
Fishsticks Fishsticks is offline
Car: E60 535
Default 05-07-2013, 06:02 PM
This might be a no brainer to some, but I'll say it anyway. Drive the car around for 10-15 minutes before you start ripping 3rd gear and allow the ethanol to mix with the 93 and make its way from the tank to the motor. This is especially crucial for anyone running Cobb since you are switching maps and there is no auto tune like JB4.
  • 08 Jet Black 535i - Sport Package - Nav
  • Appearance: M5 Front Bumper - JB Kidneys - Tinted LED Side Markers - Cree LED Angel Eyes - 5000K HID Fogs - 15% Tint All Around
  • Suspension: 20" Vossen CV4 - KW V2 - BMS Wheel Spacers
  • Performance Goodies: Cobb AP - Aquamist HFS-4 - ar design *** - Magnaflow Catback Exhaust & Race Cats- ETS FMIC - ER Charge Pipe w/ Tial BOV - BMS DCI & OCC
willizm's Avatar
willizm willizm is offline
Default 05-07-2013, 10:04 PM
are you guys seeing much of a performance difference going from a 30% mix to a 50%?
2009 335i stock.....for now.
2001 Trans Am PT8285
2010 Escalade tow pig
2013 f150 ecopoop
BimmerNFS's Avatar
BimmerNFS BimmerNFS is offline
Car: 2009 BMW 335i E90
Default 05-07-2013, 10:44 PM
has anyone ever tried 100% e85... is it possible???
2009 BMW e90 335i 6AT, Sport Package, Cold Weather Package, Premium Package, Logic 7, Space Gray Metallic, Dakota Gray Leather
BMS DCI, BMS JB4 G5 ISO, BMS OCC, BMS CP
BimmerNFS's Avatar
Default 05-07-2013, 10:46 PM
or is it not a good thing to do?? i have stations by be that have 115 octane race fuel and have so whanted to try it but dont want to damage anything
shaunlsone shaunlsone is offline
Car: 09 e92 335i sport
Default 05-07-2013, 10:51 PM
with just a jb4 and dci kit what is the rwhp gains on running 40%e95 with 93oct??
v8bait's Avatar
Car: E92 335i 6MT
Default 05-07-2013, 10:54 PM
Past E50 has fewer gains but it never hurts. As for straight E85 it's possible yes but depending on your setup and goals is going to cost much more to pull off. You're talking lpfp upgrade, hpfp upgrade, backend flash, etc. E50 is achievable for many on the jb4 alone.
Just try to use unleaded race fuel, the leaded stuff you can use but you may be looking at O2 sensors prematurely. Otherwise race gas is safe.
BimmerNFS's Avatar
Default 05-07-2013, 10:57 PM
I was just asking because i have a car that is e85 comparable and it is SOOOO much more powerful with 100% e85 that normal 93 octane. I guess i need to do some more research about e85 but what is the difference? is it worth it? should anyone try it? a lot of questions...
AWil335i's Avatar
AWil335i AWil335i is offline
Car: 2007 335i
Default 05-07-2013, 10:59 PM
this is right on, per usual... Just installed the in-line LPFP upgrade and flash and saw some dips in the HPFP on 100% E85. I'm now close to 75% and plan to log tomorrow!
When I would run 50% E85 before the pump upgrade and flash, my low-pressure would dip but I was still able to maintain high pressure.
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS *** | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
BimmerNFS's Avatar
Default 05-07-2013, 11:09 PM
damn thats a lot of work... i have been so tempted to just do a complete over haul over my entire engine (blueprint, rods pistons, block, all external accs) so much work tho damn lol
BimmerNFS's Avatar
Default 05-07-2013, 11:10 PM
i guess i just want the best sleeper in the area.. i already have people in mustangs and camaro that think they are going to destroy me get their butts handed to them... i wanna own GT500's and ZR1's even GTRs if possible
v8bait's Avatar
Car: E92 335i 6MT
Default 05-07-2013, 11:14 PM
I saw the same thing.
Bimmer- I am willing to bet your last car on 100% E85 was port fueled. Direct Injection is much different, and with E50 you can suppress knock better than straight E85 on a port fueled car. Although we are also running more compression than one of those typically runs, but it's not an apples to apples comparison. You only need as much E85/octane as the conditions/tune/hardware require. Anything more is just extra safety with little benefit.
BimmerNFS's Avatar
Default 05-07-2013, 11:17 PM
Thats good to know.. i have just wanted to beet one person in my area... a 1300hp 90s toyota supra.. i NEED some major power improvements.... not sure that i can do anymore lol
thenewrick's Avatar
thenewrick thenewrick is offline
Car: 2007 335i E93 in Black Sapphire Metallic
Default 05-08-2013, 11:41 AM
I gained about 75hp and 150tq at the crank going from stock to jb4 map 5 with just DCI and 30% E85 blend.
Run 1 is with DCI
E85 torque curve very smooth.
I was watching the boost levels in real time and it only hit 17psi very briefly once so there was still some room to grow on the autotune map.
I'm running roughly 40% E85 blend now with no problems except rough start-ups sometimes.
v8bait's Avatar
Car: E92 335i 6MT
Default 05-09-2013, 07:51 AM
You should look into the Vargas stage 3 stuff and a built motor and nitrous, plus ALL the supporting mods on a 6mt. I mean 1300hp is no joke. Gonna take more than fbo and e85 to take that if he's hooking up and in kill mode.
Default 05-09-2013, 04:47 PM
There is no 335i in the world that can touch a 1300hp supra. If you are looking to beat cars of that caliber, then you should be looking into a different platform (for now atleast). 2013 gt500's, GTR's, ZR1's is going to take upgraded turbo's like VTT stg. 3, but with mods those cars are also in a different league.
Young_Man Young_Man is offline
Car: E90
Default 05-09-2013, 05:37 PM
This is the same as E85 right? I'm thinking about placing an order...
http://www.dragzine.com/news/vp-raci...l-racing-fuel/
smolik smolik is offline
Default 05-09-2013, 06:12 PM
I put down 270whp/270tq stock. 370whp/430wtq tuned.
Default first wot run - 06-09-2013, 05:48 PM
filled up w/ 4gal of e85 then filled up w/ 93. only had time for 1 wot run but from what i can tell things felt and look pretty decent. anyone have any thoughts. log below.
v8bait's Avatar
Car: E92 335i 6MT
Default 06-09-2013, 06:41 PM
Timing is low still, either due to not enough octane still or not enough adaption runs. I'd try to do at least 2 or 3 WOT runs in 3rd or 4th, then take the log.
Regardless, there's room in it for a stronger mix as fuel pressure is fine and FP mapping is 82 (out of 100 max). Maybe next time try 5-6 gallons to a full tank. Logs are otherwise normal.
How does it feel?
aoschadlin's Avatar
Car: 535i
Default 06-09-2013, 09:15 PM
I think is meant to be a "better" version of e85. But from my limited online research it seems expensive? ie $7/gallon. Did you get pricing on it?
MasterWang MasterWang is offline
Car: 2007 335i e92
Default 06-09-2013, 10:07 PM
I may be completely wrong here, but I always assumed these were my numbers
93oct using map1 or map5 = 340hp
50% e85 + 93oct using map 5 = 390hp
