(#76)
F32 F32 is offline
Car: 435i
Default 10-12-2013, 02:01 PM
N55 cars haven't been out as long and certainly don't have the same R&D time behind them as N54s, so it's understandable if the jury is still out and might take some time. But the whole testing and tuning and logging ordeal doesn't have me intrigued.
The 435i will be my beater and starting next year, my M-F work commute will be <5 miles round-trip. I'll mod it, but I'm not going to mess with worrying about messing with the tune and be the dweeb driving around with a laptop in the car logging. With E85 available locally, it would be nice to just mix 50/50 with 91 and enjoy the extra power.
Default 10-12-2013, 02:26 PM
Diagnostic values for N54 and N55 are the same, we are still looking at temps, timing, boost, targets, etc. However the N54 is able to handle more aggressive settings due to the broader DME access. N55 is more restrictive since it's a different DME platform.
Also the engines are identical except N54 is twin turbo, N55 is single twin scroll.
DinoNac's Avatar
DinoNac DinoNac is offline
Car: F10 535xdrive
Default 10-12-2013, 03:58 PM
I was thinking about the timing parameters and AFR specifically. So you're saying the target values are the same then?
2011 F10 N55 xDrive MSport
BMS JB4 STG 2, BMS SCI, COBB FMIC, Dr. Euro CTLS DP AA Custom CP, MEISTERSCHAFT GTS
Triple Mishimoto 12" fans, with Dual Drerale Controllers
Flex Fuel Connectors, 45% E85
BMS 2.3 METH Kit, 30% tint, BMS HID Fogs
Durimone54 Durimone54 is offline
Car: E82 135i
Default 10-15-2013, 09:14 AM
I'm sure this is a stupid question but, does it matter while mixing if you put e85 first then 93?
aoschadlin's Avatar
Car: 535i
Default 10-15-2013, 09:16 AM
Personally I've always put the e85 in first to allow the 93 to mix it all up. Been doing it for about a year now?
No scientific basis for this of course.
Fmonteiro444's Avatar
Car: 09 E92 SG
I do E85 first so I can put in the right amount of gallons. Then I can just top off with 93.
Car: E82 135i
Default 10-15-2013, 09:32 AM
Thought so.
Guess the only thing I've been doing wrong is every other tank filling up on 100% 93 just to clean out the e85.
Luis2006 Luis2006 is offline
Car: BMW 335i
Default How many gallons of e85 can I do - 06-17-2017, 09:29 PM
I have a 07 335i Manuel I have down pips duel cone jb4 stage 3 clutch and I want 2 no how many gallons I can run?how can I make more power if some1 can help me?
My email is luisl767@gmail.com
JayJ JayJ is offline
Car: 135i N54
Default 06-18-2017, 12:41 AM
With an E85 test tube, mix e30, add to an empty as possible fuel tank, do a few runs to help the car adapt, log and post in the support section.
From there you will need the E85 Flash and stage 2 LPFP, but post the logs as mentioned above and guys will assist you from there.
gregsatt gregsatt is offline
Car: 2011 335is
Default 03-01-2018, 03:03 PM
Hey everyone. I've got a 2011 335is with a 7 speed DCT. Only mod other than the JB4 is a Cobb drop in filter and a Cobb charge pipe.
Can you guys look at my logs and give me your opinions please?
5 Gallons of E85 mixed with 93 octane. Temp is 59F. High humidity if that matters...
The first number of pulls are right after the fill up and are to calibrate map 5. The last few should be pretty representative. Please let me know how it looks and if I can go another gallon or two.
I've put the log file on Google drive, hopefully you can see it.
https://drive.google.com/open?id=1MM..._5M-zaaApF0oJW
Thanks for your help!
Greg
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 03-05-2018, 09:05 AM
Greg
you really need to post in the right section - Support section. Also include csv logs in post if possible.
Car: 2011 335is
Default 03-05-2018, 09:29 AM
Thanks. Which section is the right section? I'll post the CSV logs in the right place, just don't know where...
dsjr2006 dsjr2006 is offline
Car: E90 N54 Xi
Default 03-05-2018, 01:22 PM
Here: http://www.n54tech.com/forums/forumdisplay.php?f=35
Upload your CSV to datazap or similar log hosting/chart service.
Create your own thread there, don't hijack another. Also usually not good practice to revive a dead/old thread unless it's a follow-up to the original.
Good luck.
E90 N54 XI-AT VRSF down-*****, Chargepipe -Tial BOV, 7" FMIC, Borla Catback, 255 Inline pump, JB4 w/backend flash
