Ga.silva10 Ga.silva10 is offline
Car: F22 M235i
Exclamation problems with n55 f series wmi kit - 02-05-2017, 10:02 AM
hello terry, i am having some problems with the water methanol kit. i think its not working well because when i run map 3 the meth gauge on jb4 mobile app show 100% all the time. it doesnt move. one day when i turned on the car and the meth gauge was at 65% and when accelerate the gauge began to increase ( i think was working well) but minutes the it gets stucked in 100% again. in the running analisis the meth starts at 100% and makes an horizontal line in the graph.
meth boost aditive: 40
meth flow scaling : 60
start meth flow: 10 psi
the other problem i am having is that some times when i turn off the car and i was using map 3 . when im going to turn it on later the car doesn`t starts up well, starts up like low in revs for a moment.
thank you
Default 02-05-2017, 10:05 AM
Sounds like a wiring issue if you get a meth signal when the meth is clearly off.
Car: F22 M235i
Default 02-05-2017, 10:10 AM
but when i prime the system it works, and some times work well what should i do ?
Default 02-05-2017, 10:20 AM
If you want me to look it over post some photos of the installation, including where the blue signal wire is connected, a JB4 log so we can check settings, etc.
Car: F22 M235i
Exclamation 02-05-2017, 07:30 PM
hello terry, i verified the installation and all was like it should be. today i turn on the car and the meth gauge was at 62 but later the gauge was starting at 90 and later the gauge get stuck 100 (it is normal ?)
images:
you can see that it starts at 90 but in the last photos the revs are in ranlenti and the meth gauge shows 100. when i use map 0, 1, 2 the meth gauge stays on.
logs: are short logs but yu can see that when the gauge get stucked in 100 the meth graph is 100 all the time i think there´s a problem
Size:  105.2 KBmap 3 gear 1-2.csv
log enviar .csv
thank you
Car: F22 M235i
Exclamation 02-05-2017, 07:32 PM
log enviar .csv
map 3 gear 1-2.csv
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 02-05-2017, 07:44 PM
Attach CSV files not links.
Mods: Stock for now
Car: F22 M235i
Default 02-05-2017, 07:49 PM
how can i do that ?
Car: F22 M235i
Default 02-05-2017, 08:17 PM
2017-02-05 20_17_38.csv
Car: F22 M235i
Default 02-05-2017, 08:22 PM
tomorrow i will send more logs running maps 1,2,3 to show that in map 0,1,2 the meth is active
Lowon's Avatar
Car: Bmw M2
Default 02-05-2017, 10:38 PM
Originally Posted by Ga.silva10
how can i do that ?
There's a manage attachments button on posts.
You should probably check the connections from the FSB, pump, and solenoid and going to the jb4 again Incase something's wired wrong.
Mods: Stock for now
