Casrio Casrio is offline
Car: 12 135i
Default First time JB4 user - 09-18-2020, 10:22 PM
Hi Guys!
I just wanted to check if everything is well with the car. Currently running Map 1 with a mostly stock setup with an upgraded charge pipe on 93 octane.
Logs
bandook bandook is offline
Car: 2013 335i
Default 09-19-2020, 08:36 AM
Welcome to the forums! You should probably upload the log. You can attach the .csv just as you would a picture.
Car: 12 135i
Default 09-19-2020, 09:00 AM
Sorry about that, here goes
AC Tuning AC Tuning is offline
Car: M4 Competition
Default 09-19-2020, 09:34 AM
Can you upload a clean log, one pull from around 2k rpm to redline?
Car: 12 135i
Default 09-20-2020, 02:32 PM
I apologize, still new to all of this. I did a couple at 2k like you said. Thanks
Default 09-22-2020, 01:55 PM
hey it looks like you jump from 4th to 2nd, then to 3rd.
Can I see a log of just 3rd gear, WOT, 2k to redline, traction fully off. Shift into 4th, slow down, and end log.
Be safe
