sicknick530's Avatar
sicknick530 sicknick530 is offline
Car: 2011 BMW e92 n55
Default Firmware update 5_18_t2.hex Car Running Horrible! - 08-27-2020, 08:44 PM
After updating my firmware to the 5_18_t2 my car is running like completely s***! I tried different maps(0,2,1,5,6). Feels like bad misfires codes 281A & 281B keep putting me in limp mode. Hereís a log from today.
Mods: JB4 with MHD back end flash, xHP stage 3, ********, AFI intake, BMW performance exhaust.
Default 08-30-2020, 07:05 AM
Hey,
Just to rule out a firmware issue- have you reverted back to the old firmware / does the car behave normal?
Settings also sometimes get reverted when making a firmware change, it would be worth a user adjustment / setting check to make sure.
Default 08-31-2020, 12:41 PM
Yes I have. Multiple times & every time I go back the car runs great again. Settings all look the same as far as I can tell.
Default 08-31-2020, 10:03 PM
double check settings to make sure.
But something has to be up if everything works on the old firmware.
andrews013's Avatar
andrews013 andrews013 is offline
Car: 2013 E92 335i xDrive
Default 09-01-2020, 09:17 AM
I had a similar issue forever. I think they might be related. It occurs for me if the car has been turned off for a few minutes, but it would run fine as long as it was left for 15 minutes or so. I even replaced my jb4 board and still had the same issue.
Are you running the E85 BEF? My issue seems to have gone away (finally, this week after months of getting stranded) after switching to the pump gas flash.
This had been called out as an issue by a handful of people in the main thread (E Chassis N55 JB4 - Page 108 - N54Tech.com - International Turbo Racing Discussion) but Terry refused to do anything without a log. Problem is that it's impossible to take a log when you can barely even start the car.
2013 E92 335i XDrive
JB4, MHD E85 BEF, EOS PI, Fuel-it Stage 2 LPFP, XHP Stage 3, XDelete Sport, 3.5 Bar TMAP, VRSF 7 HD IC, GFB DV+, VRSF D/P, VRSF CP, PE Mod, ST V1 Suspension.
Default 09-01-2020, 09:38 AM
Iím running the 98gob pump tune. My car runs & drives but feels like itís misfiring very bad. I was able to log a run. Did you go back to the 5_17 firmware?
Default 09-01-2020, 09:45 AM
When Iím updating firmware and have mhd bef installed do I have to flash mhd back to stock before updating JB4? Or reinstall mhd after I update JB4? I have menu 4 set to 2 for bef mode & JB4 set to my normal map I use (map 5)
Hey,
Default 09-01-2020, 01:46 PM
No you can update your JB4 firmware with the BEF flashed
Default 09-09-2020, 11:20 AM
Ok then I guess Iíll have to update firmware 1 more time and send a screenshot of my settings?
Default 09-09-2020, 07:38 PM
Letís give it a shot.
You can run the older firmware
Default 09-11-2020, 08:23 PM
These are my settings with 5_17 firmware
Duty Bias all read zero
Let’s give it a shot.
Last edited by sicknick530; 09-11-2020 at 09:21 PM.. Reason: Attachment was missing
Default 09-12-2020, 06:50 PM
log?
