Choyo_n55 Choyo_n55 is offline
Car: E90 335i n55
Default 321d code evap system small leak - 08-25-2020, 12:10 PM
Hello, does anyone have experience with code 321d evap system small leak, the code appears every time when I start the car, the ses lamp lights up, there is no change in the behavior of the car ... on map0 and map 4 the code does not appear .. .
2011 e90 n55, vrsf down pipe,cp,fmic jb4,AT xhp stage3
Default 08-27-2020, 08:49 AM
It's not a code we see coming up often, but if it doesn't come up on map0 must be related somehow.
JB4 log to see firmware version and control board type? One thing to test would be putting brown manifold connection only back to factory.
Car: E90 335i n55
Default 08-27-2020, 09:58 AM
do you mean to return the stock connector to the map sensor of the intake manifold? firmware 5_18_t2
Car: E90 335i n55
Default 08-30-2020, 12:06 AM
Bump,Terry?
Default 09-02-2020, 08:01 AM
Yes, the brown JB4 manifold sensor connection to factory as a test.
