conradhobbs conradhobbs is offline
Car: Infiniti Q50 3.0t Luxe JB4
Default 2018 Q50 3.0t Luxe Firm V8 Settings - 06-20-2020, 12:46 PM
I saw the new map settings for V8 firmware, but I was wondering if anyone could provide more details on how to use the fuel wire control settings? (or direct me to correct thread) I have the model where everything was connected to the circuit board. All I had to do was connect Bluetooth dongle and tap the black wires to white on each side and plug in.
(I was able to finally do the V8 firmware update. To put a 2018 Q50 into ACC mode (Eng off but ACC power on for update) you have to press the start button 3 times. The engine should shut off but ACC on. It took a while for the BT download but stayed in ACC till finished.)
Thank you,
Conrad
Default 06-20-2020, 01:13 PM
There are no setting changes required for the fuel control wires other than to enable them in options.
Default 06-20-2020, 03:49 PM
Sorry, how do I enable that?
