jsbowling42 jsbowling42 is offline
Car: Q50 Red Sport
Default 04-06-2020, 06:48 PM
so just curious but why dont we have a actual target PSI, without doing the addition in excel of ecu_PSI and target. i would think it would be useful considering we are looking at a PID control to try and keep boost from leading or lagging target right?
dajcopeland dajcopeland is offline
JB4
Car: Q60 Redsport
Default 04-07-2020, 07:14 AM
Hi Terry. I flashed to v8 t8 and raised duty bias and FF to 60 on my Q60 RS. The boost felt inconsistent so I backed down to 55 which was a little better, but on my car 50 seems to be the sweet spot. I'm on 93 octane. Sorry did not capture a log this time.
Car: Q50 Red Sport
Default 04-07-2020, 07:24 AM
if there were no codes displayed then i would say double check the settings and then do a pull with a log. so we can really see whats going on and get you to lol. im sure Terry will help as well, he is great.
JB4
Car: Q60 Redsport
Default 04-07-2020, 07:47 AM
Yeah I've been watching what your car is doing as a road map. I don't run any ethanol and I have my boost turned up a little higher. I might need to dial it back a little now that we have EWC. When I have an opportunity I'll catch a log soon.
Car: Q50 Red Sport
Default 04-07-2020, 07:53 AM
yeah i would start with a tapered +4 map on 93 fuel, and EWG connectors will cause the boost to come in sooner so depending on how good the 93 is and what your car likes you might have to do some tweeking. but to start i would bump down the boost some and log to go from there. if its happy then we can always turn it back up
Here are the default map 1 settings:
3.0 '1500
3.5 '2000
4.0 '2500
4.0 '3000
4.0 '3500
4.0 '4000
4.0 '4500
4.0 '5000
3.5 '5500
3.0 '6000
2.5 '6500
2.0 '7000
Default 04-07-2020, 09:22 AM
Originally Posted by jsbowling42
Itís a E15 mix. Should be 94 octane.
OK let's see a log on map2.
I use this photo a lot.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-07-2020, 10:25 AM
I've been refreshing so many times a day trying to purchase the EWG connectors lol
12.64 @114mph
0-60 4.46
Car: Q50 Red Sport
Default Map 2 log - 04-07-2020, 12:10 PM
Here is a map2 log. still following targetAcc well with afr staying 12 or below. thoughts on circle? knock or still timing drop until peek boost?
JB4
Car: Q60 Redsport
Default 04-07-2020, 01:49 PM
Terry, I had a little time over lunch to grab a few logs. Two short runs, a highway run, and one while manual shifting. Bumpy road on the short runs so had a little difficulty staying on the pedal. Hopefully enough there between four runs to give you a nice overview. This is on Map 6 with duty bias set to 50 across the board. 93 octane.
Car: Q50 Red Sport
Default 04-07-2020, 02:02 PM
we will wait to see what Terry says since he is the tuner, but this circled area could be knock. again im not a professional lol just someone trying to learn and help
Default 04-07-2020, 02:55 PM
Could be a minor timing correction but isn't the usual pattern of a sharp drop.
Looks more like a mapped timing change since boost is also increasing at that same instance.
Car: Q50 Red Sport
Default 04-07-2020, 03:09 PM
Anything you want me to try?
Default 04-07-2020, 03:23 PM
Don't see your latest CSV on this page. I think I said log map2 next?
Car: Q50 Red Sport
Default 04-07-2020, 03:38 PM
its post #34
N54Tech.com - International Turbo Racing Discussion - View Single Post - JB4 VR30 EWG Connectors
JB4
Car: Q60 Redsport
Default 04-07-2020, 05:08 PM
Terry, do you recommend I stick with 50 as my duty bias?
Lonmon Lonmon is offline
Car: 16 Infiniti Q50 3.0t AWD
Default 04-07-2020, 09:25 PM
You and me both!
2020 BMW M340ix Portimao Blue
K&N drop in, JB+, Intake muffler delete
2016 Q50 Premium 3.0t AWD (GONE)
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
JB4 W/fuel wires Map 6 custom
E20ish mix made 413whp 410wtq (17-18psi peak)
Car: q50
Default 04-08-2020, 04:18 AM
I must have just timed it right when I ordered. It was still about a 2 week wait but I managed to get a set sent right before we had the lock down. Best part was going WOT the first time after the install.....and had ZERO boost. Looked back through the documentation and realized what was the WMI map was now the Valet Mode map. Switched to the new WMI map and the car was immediately an animal. Now its pretty much no traction 40 or below
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Car: Q50 Red Sport
Default 04-08-2020, 07:31 AM
yeah, i just happen to refresh the page and saw they were is stock.... so i was like buy buy buy lol ddnspider what settings/setup you currently running?
Car: q50
Default 04-08-2020, 08:42 AM
I think I have it set for around 55 across the board. I'm also on WMI so can run higher boost, but haven't really felt the need to mess with it.
Q50 Premium RWD
BMS HE
Low cost LSD
Default 04-08-2020, 08:48 AM
Looks good to me overall. For kicks you can do the same run FF = 70 next for comparison.
On timing maybe a minor drop, hard to tell.
Default 04-08-2020, 10:13 AM
Could use some more VR30 install photos for the first post so if you've installed them feel free to post photos here.
Cali_Q50 Cali_Q50 is offline
Car: Infiniti Q50
Default 04-08-2020, 11:46 AM
Hey Terry, can you take a look at these 2 runs running on E30 map 4
Car: Q50 Red Sport
Default 04-08-2020, 12:23 PM
Here is ff =70, map 2.
curious why the timing doesn't drop to zero like it typically does during a shift?
