(#301)
Punisher's Avatar
Punisher Punisher is offline
Car: 2019 Kia Stinger GT1 RWD
Icon1 Log check after EWG Install - 10-05-2020, 10:39 PM
Hello Terry,
Log check please.
Map1 on 93oct Exxon fuel. No MIL Codes. Hits real hard but has some intermittent hesitation on top end.
Current Mods:
BMS 450hp KIT:
>JB4 21/19//5-FIRMWARE
>BMS OCC
>BMS INTAKES + FILTERS
>DENSO 5346 IKH24 @ .022
BMS EWG ADD ON CONNECTORS
(installed driver side on pin 8 & 14 and passenger side on 9 & 19)
All User Settings in JB4 are set as specified on page 1 of this thread.
Thanks.
Default 10-06-2020, 10:03 AM
Don't see any obvious issue in the log. Map2 run for comparison?
Sboylan Sboylan is offline
Car: Kia stinger gt1
Default 10-06-2020, 01:01 PM
I got a random 25A1 code today. What does that code mean?
Default 10-06-2020, 04:46 PM
Might be boost too high or WGDC too high. If becomes a trend log when it's coming up.
Punisher's Avatar
Default 10-06-2020, 05:04 PM
Hi Terry,
Thanks for the log check. Here is the log for MAP2 as per your request. Looks like it appended to the previous file. I have it set for 24hrs. Hits real, real hard now and pulls all the way to redline without any hesitation. (Love the sound of these BMS intakes, whooosshhh)
I have two cans of Boostane. If this log is good, I can run a log at 100 octane or above on next test hit.
Sorry it took so long for my reply.
Much appreciated...
Default 10-06-2020, 05:06 PM
Looks good to me! Next up map3.
Punisher's Avatar
Default 10-06-2020, 07:50 PM
Hey Terry,
WOW. MAP 3 with Boostane measured out to 100oct (10oz. for 10 gal) is a neck breaker. Pulls extremely hard all the way to redline in every gear.
Here's the log for this last run. It was partially in MAP2 (map3 starts on line 323)until the Boostane got fully mixed with the fuel through the rail to the injectors.
Thank you sir.
twister68's Avatar
twister68 twister68 is offline
Car: 2017 Q60 RS
Default 10-09-2020, 04:41 PM
Running 2021 G70 3.3T on 93 gas Map 2 and CAI with fuel wires and EWG now after putting some miles on the car, been looking for required settings for DWP, PID Gain, FF etc can someone help a fella out please?
Love it btw Terry even more than I did on my Q60 RS..... have some suggestions on CAI's though in terms of fitting....
Twister
2021 Genesis 3.3T
Siberian Ice
JB4 kit with EWGs MAP 2 94RON
Feeling the JB4 difference
Default 10-09-2020, 05:31 PM
Originally Posted by Punisher
Hey Terry,
Thank you sir.
Seems fine to me!
Punisher's Avatar
Default 10-10-2020, 09:28 PM
Thanks Terry. Best customer support ever!
I ran a 13.29 ET in the 1/4 at Evadale Raceway TX, bone stock, in mid-summer down in SE Texas. Can't wait to see what it'll run now if the dang hurricanes will slow down for a minute.
**WMI Kit next**
Sincerest Regards,
-Punisher
Neoghost068 Neoghost068 is offline
Car: 2018 Kia Stinger GT2
Default 10-14-2020, 10:51 AM
Jb4 disabled in map 2 shifting between 4th and 5th, im thinking AFR dipped to low at high RPM??? any suggestions? Currently have agency power intakes, go fast bits respons BOVs set to full atmosphere, ARK mid ***** and ARK catback, fuel wires are active and EWG wires installed and user adjustment set according to the first page
