(#176)
Alanz Alanz is offline
Car: Audi
Default 09-08-2020, 09:44 PM
Originally Posted by zensunnidx
any ideas of the gains from Map 2 and Map 3 for this engine?
+1 psi
Map 2 is +4
Map 3 +5
Thatís the target
eric81 eric81 is offline
Car: Golf 7 PP opf
Default 09-15-2020, 06:52 AM
Hi short question to you.
Do I have to connect the AFR line to the JB4 for a Golf 7 GTI Performance 245ps MJ 2019/2020 with OPF/GPF filter?
Default 09-15-2020, 07:28 AM
Note that the engine in your car is not a Gen3B so if you ever update the firmware its a normal Gen3 motor.
It is only needed for map 2 and up.
Kellen Kellen is offline
Car: 2018 Passat
Default 09-23-2020, 02:21 PM
What issues would you see if people ran the 2014+ VW Passat 1.8T Gen 3 170hp JB4 on the Gen3b motor? or vice versa?
Default 09-23-2020, 02:37 PM
You mean if the same JB4 was used between the cars? There would be a fuel pressure sensor fault. The Gen3B uses a SENT protocol sensor and the Gen3 uses a voltage based sensor. It is Plug C on the side of the manifold that collects this signal.
Car: 2018 Passat
Default 09-23-2020, 02:49 PM
Yes, someone was selling a JB4 for a gen3 1.8t Passat and said it can be used interchangeably between that and the gen3b 2.0t passat. Which I laughed at, and asked why you/they would go to the trouble of creating the specific gen3b jb4 if you could just use the existing module.
NymeeXX NymeeXX is offline
Car: 2020 Tiguan
Default 09-28-2020, 02:48 PM
Likely a question for George.
I installed a JB4 in my North American 2020 Tiguan today and the JB4 mobile app is reporting firmware version 26/3/5 vs 26/2/5. I don't see any release notes for 26/3/5.
Anything worth sharing?
BTW this is my 3rd JB4 and so far I'm very pleased with the performance and reliability of the units.
Thanks.
Car: Audi
Default 10-01-2020, 09:21 AM
Thanks.
Just an update for the rev3.7 wireless kit I believe
Default 10-01-2020, 06:19 PM
Thanks.
As Alanz mentioned its got a compatibility patch for the Rev3.7 bluetooth device.
Car: 2020 Tiguan
Default 10-06-2020, 12:52 PM
Thanks guys.
kobz360 kobz360 is offline
Car: Audi A4 40 TFSI
Default 10-09-2020, 09:32 PM
Hi George (and all),
I'm from Australia and I've got a 2019 A4 40 TFSI (190hp). I was wondering if I need any modifications to run map 2? I'm just looking to keep the car as stock as possible while I've still got warranty on it. Either way I'll definitely be looking at picking up a JB4.
Cheers!
Default 10-10-2020, 08:54 PM
Cheers!
Its fine to run map 2 with no hardware. If you on 98Ron fuel you can run map 3 too.
ub3rn3rd ub3rn3rd is offline
Car: 2017 Golf R
Default 10-16-2020, 10:34 AM
Is map 1 compatible for 87oct or 91oct is must. This is incase the wifey puts cheap gas
Default 10-16-2020, 05:51 PM
From all the logs I have seen map 1 is fine to use on 87.
