zort zort is offline
Default Suspension knock - 08-01-2018, 11:51 AM
Hey Guys,
I need some guidance understanding the front suspension of a 2007 e90. On normal roads with pot holes etc there is no problem. However once I make a sharp right into the driveway you hear a knock once the wheel dips for the drain.
I don't understand why this would not happen with regular holes not turning.
All the same I check the suspension and all seems fine however since this is only happening on a turn where should I be looking specifically.
Thanks in advance.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 08-02-2018, 11:45 AM
It's hard for someone on the internet to diagnose with that little info.
What checks did you do?
Jack up the car, get under, and look for worn/cracked rubber bushings, torn ball joint boots, and check the tie-rod play, etc. take pics, let us know what you see.
Or take it somewhere for free diagnosis, and let us know what they say.
Default 08-02-2018, 12:13 PM
Fully understand. Honestly I was hoping that no knock under normal driving conditions vs knock on a hard turn would have helped.
Will do the check.
-B
