(#651)
Ct18r Ct18r is offline
Car: 18 golf r
Default 02-07-2020, 09:49 PM
Originally Posted by EpTx_GLI2016
Attached FilesJB4_EA888_8_5_1.hex*(58.6 KB, 5875 views)JB4_EA888_8_6.hex*(58.2 KB, 195 views)
I downloaded JB4_EA888_8_6.hex
Currently have JB4_EA888_8_5_1.hex installed.
Are you using the app? That’s the only way I know how. Are you clicking the correct one to upload to jb4?
EpTx_GLI2016 EpTx_GLI2016 is offline
Car: 2016 Gli
Default 02-07-2020, 09:56 PM
The app have updated firmware before with no issues.
Got it to work now shows Firmware version is 60/86//5*.
Thanks.
Default 02-08-2020, 06:11 AM
Thanks.
That's the correct one. Where you selected the 8_6 file?
DomCupra DomCupra is offline
Car: Leon Cupra 280
Default JB4 dont work in Cupra 280 - 02-09-2020, 10:59 AM
hello, i bought a used jb4 and installed it in my leon cupra 280 hand shifted. after installation, the EPC lamp and engine warning light came on. the Car stutters and goes out in all maps. The connectors are all on the Right Place. the jb4 was previously installed in a Skoda Oktavia RS. what could be the reason that it does not work in my car?
silver_alpha6 silver_alpha6 is offline
Car: C7 A6
Default 02-09-2020, 05:15 PM
Question, is there a way to tune the trans via JB4? I ask bc I've drove just a little over 800 miles with the jb4 on and the trans is slow to upshift when at WOT. There's about a 2 - 3 second delay before the shift.
Second question, is there a way to monitor KR with the JB4?
TIA.
Car: 18 golf r
Default 02-09-2020, 05:17 PM
TIA.
Negative. Get a tcu tune. Kr?
Car: C7 A6
Default 02-09-2020, 05:30 PM
KR aka knock retard. premature detonation pretty much.
a tcu tune will void my warranty right?
Car: 18 golf r
Default 02-09-2020, 05:33 PM
I would’nt know anything about the warranty issues. Monitor ign1 for overall advance and ign2345 for timing pull in individual cylinders.
Car: C7 A6
Default 02-09-2020, 05:37 PM
Awesome, thank you. It's been about 9 years since I've done any tuning myself so it's back to the basics.
Default 02-09-2020, 06:49 PM
TIA.
Cannot do the TCU, you will need to flash it.
Timing adaption is ign2-5 in the logs.
Default 02-09-2020, 06:51 PM
The unit is compatible to the Cupra so potentially there is a issue on one of the connectors or possibly a firmware problem. I got your email so we can move to that and get it resolved.
andrew149 andrew149 is offline
Car: 2019 MK7 GTI 6 speed
Default 02-09-2020, 07:04 PM
Wanted to check this is the latest update correct JB4_EA888_8_6.hex. Took me about 500 tries with bluetooth to flash at first i was connected to the cars bluethooth with the jb4 i was able to disconnect that still failing and then after another 50 tries i change the ping time from 10 to 30 (i think it was ping?) anyways i was able to flash the 8_6 after a million attempts
JB4_EA888_8_6.hex
Car: 18 golf r
Default 02-09-2020, 07:10 PM
JB4_EA888_8_6.hex
Turn off Bluetooth in the car. Pop hood and put phone near bt connect kit then press upload. Makes a huge difference for the upload signal.
Rekt Rekt is offline
Car: Golf R
Default 02-09-2020, 10:17 PM
When does the beta flash firmware become a real version?
Car: Leon Cupra 280
Default 02-09-2020, 11:15 PM
I send you a E-Mail
Default 02-10-2020, 05:34 AM
JB4_EA888_8_6.hex
Yes, that is the latest.
lumberjackzach's Avatar
lumberjackzach lumberjackzach is offline
Car: VW GTI mk7
Default 02-10-2020, 02:35 PM
I've been thoroughly enjoying the beta. Very smooth in low RPMs. My engine mounts are too stiff and the vibrations dropped a lot with beta firmware. Great job
Default 02-10-2020, 04:08 PM
Thanks for the feedback.
For guys catching up we have listed it in post 1 now and its out of beta so you can go ahead and update with no concerns.
TSI 1.8T Jasper's Avatar
TSI 1.8T Jasper TSI 1.8T Jasper is offline
Car: 2018 mk7.5 1.8T m/t
Default 02-10-2020, 06:19 PM
Thanks for the new firmware update, question for you in have map6 setup as following
11 12 13 14 15 15 16 15 13 13 12 12
Fuel loop at 60
Question i have my boost safe set at 19 is this fine or should it be higher
Manual 1.8t ******* down pipe with full catback and intake 93 octane and intake
Default 02-11-2020, 05:08 AM
Fuel loop at 60
Those are good. Its the typical map 6 we start with.
Default 02-11-2020, 05:51 AM
Cool and thanks
GerdaMk7R's Avatar
GerdaMk7R GerdaMk7R is offline
Car: 2016 Mk7 Golf R
Default 02-12-2020, 10:13 PM
It definitely feels much smoother at lower RPMs. Nice work. Thanks.
goodvibes goodvibes is offline
Car: VW Alltrack
Default 02-17-2020, 09:16 AM
Love the update. I'm on map 3. Very noticeable acceleration increase from map 1 but so smooth. Like a stronger factory motor. Alltrack, 1.8, dsg, 93 octane.
Any safety advantage to map 4 or is map 3 just that well suited to the smaller Turbo. It can get into the 90's here (Chicago) in the Summer but generally humid.
Default 02-17-2020, 09:45 AM
I reckon in the summer months map 4 will be perfect for the smaller IS12 on the Alltrack.
Car: VW Alltrack
Default 02-17-2020, 09:59 AM
Thanks man. May just put it there and leave it all year round. Just so nice to have 4 plug and play options now. Thanks for continuing to find ways of improving the product considering that your audience is somewhat captive. There are always alternatives but the versatility along with warranty and resale value considerations make the JB4 unique.
