vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 02-01-2017, 01:28 PM
Originally Posted by ratapeludismo
Hello!
You had the same problem?
I have replaced piece # 9
http://www.realoem.com/bmw/enUS/show...diagId=31_0814
I read that the last tightening must be done with the car on the ground,
It is true?
Thank you!
Yes, is true, suspension need to be loaded.
ratapeludismo's Avatar
ratapeludismo ratapeludismo is offline
Default 02-01-2017, 05:31 PM
Hello!
I remember my mechanic when he changed his upper arms did not !!
Can I reposition the arms well, or are the silentblocks already deformed?
Could it be the cause of the warping of all my brake discs?
Thank you!
EURO - E92 335i - AT - I8A0S - JB4 G5 32.2 - MHD Flash Pump - DCI - DP
vwetish's Avatar
Default 02-01-2017, 05:41 PM
Hello!
Yes! If this was recent chances are the bushings are not damaged.
Thank you!
No! It could give you a false sensation of warped disk because of the vibration but it can not warp them. That is brake component only!
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default 02-06-2017, 08:38 PM
The big question is: Are your rotors really 'warped'? The only way to know for sure is to measure run out with a dial indicator. When fitting the wheels, are you using a torque wrench and tightening the lugs in a cross pattern?
Finally, looking at the pictures of your rotors, you have a ton of deposits on them. I'm guessing you don't do much hard braking with that dark color. Go out and do 6 to 8 HARD stops (just short of ABS activation) from about 60 mph to 20 mph. When you smell hot brakes (from the pads out gassing) drive normally for about 10 minutes to cool the pads and rotors.
It's always best (and cheapest) to check the simple stuff 1st.
Totaled by a careless driver:
'08 E92 335, M sport option
Default 02-08-2017, 06:19 AM
Hello!
The disks were deformed 0.04
I installed brake pads and new discs.
Let's wait for the result.
Thank you all.
vwetish's Avatar
Default 02-08-2017, 08:14 AM
Hello!
Thank you all.
0.04 could be problematic. Check the hub run out too. Not only the disc. If hub is defective it will cause the disc to appear defective too. Inspect the hub.
Alex@abrhouston Alex@abrhouston is offline
Car: m3
Default 02-08-2017, 09:07 AM
Sounds like you need a mechanic to look at it. Stop guessing and have someone with training diagnose this for you.
abrhouston.com
832-797-9114
K100J K100J is offline
Car: 335i coupé
Default 02-10-2017, 11:43 AM
Remove your wheels. If the inside face of the wheel is painted where it makes contact with the brake disc then this is the cause. Seen it 100s of times on BMW. The heat cannot dissipate correctly if this surface is painted.
vwetish's Avatar
Default 02-10-2017, 12:03 PM
Car: 335i coupé
Default 02-11-2017, 04:05 AM
What's the confusion?
vwetish's Avatar
Default 02-11-2017, 08:50 AM
Paint! I'm sorry. Is little ridiculous.
Car: 335i coupé
Default 02-11-2017, 09:37 AM
We will agree to disagree. Hopefullly you get the the bottom of it op.
vwetish's Avatar
Default 02-11-2017, 10:35 AM
What happened with the 10y experience reply? Post this BMW instruction quide on brakes you speak of.
Car: 335i coupé
Default 02-11-2017, 11:25 AM
[QUOTE=vwetish;521028]What happened with the 10y experience reply? Post this BMW instruction quide on brakes you speak of
I'm not here to start an argument.
Also I cannot post bmw material online
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 02-15-2017, 04:10 PM
99.5% of the time, the rotor doesn't 'warp', it's pad deposits (already establish I think).
So the car is street driven, but have you considered your driving style? If you are doing a lot of heavy braking, and then sit at a red light immediately afterwards with your foot on the brake pedal, the pad material is going to stick to the hot rotor, and cause vibrations in short order.
if the symptoms are going away and returning after you do change rotors/pads, it's something related to the brakes.
If you change the pads, but don't resurface the rotors, it could be the brakes and you just didn't address the actual deposits on the rotors that are causing the vibration.
If changing pads/rotors doesn't affect the problem at all, then it's bushings, hub/bearing issue, or something else.
Default 06-22-2017, 01:14 AM
Hello friends!
I have discovered that I have a very oval front wheel.
Can this cause uneven deposits on brake discs and resemble warped discs?
A greeting!
LessIsMore's Avatar
Inner Circle Member
Default 07-07-2017, 12:14 PM
How did you determine the wheel is out-of-round?
An out-of-round wheel could cause vibration by itself, but don't see how it would cause pad deposits.
hondakow0507's Avatar
hondakow0507 hondakow0507 is offline
Luv'n the ride
Default 08-23-2017, 03:10 PM
Agreed with the control arms advice, I've also expereanced this in the past and control arms were the fix action. Yes, the reason for not tightening control arm bushing with the suspension unloaded is the bushings have a much higher probability of making annoying creaking sounds. If the suspension is loaded or in the position they would be in while setting with the cars full weight on the tires when the arms are tightened should prevent this. If installing pollyurathane bushing, don't forget to use the grease that should come with them or you'll still have that creaking sound.
I hope this helps, Good luck
vwetish's Avatar
Default 08-31-2017, 06:51 AM
OP issue was a bent wheel. Control arms aren't a fix. At least not on this platform. The bushings absorb the vibration. If they are worn out they won't but that doesn't change the fact that vibrations are coming from somewhere else. So replacing controls arm to cure brake related vibrations is basically an bandage. Root of the problem is else where...
Default 10-08-2017, 02:50 PM
Hi guys!
Again vibration in the steering wheel when braking.
I have already changed 7 times. Sometimes in warranty and sometimes not.
Can they be the calipers?
It's been the only thing I have not changed.
Thanks friends!
LessIsMore's Avatar
Inner Circle Member
Default 11-01-2017, 10:36 AM
Did you already replace the wheel?
