(#3751)
Default 10-11-2020, 08:36 PM
Originally Posted by twister68
Running v19 MAP 2 with intakes, EWG & Fuel wires....Petro Canada 94 RON (allegedly)
a couple of logs just to check everything looks cool please Terry and to see if I need to change anything....
Map 3 with Boostane next...
So far super smooth...wish I could get hand of the launch control though...
Short run but looks fine to me!
wardyl36 wardyl36 is offline
Car: Kia stinger gt
Default 10-12-2020, 07:58 AM
Hi Terry,
Please check log when you have a moment. I posted in different section by mistake. Ran a 12.5 at 112 off launch control with computer doing shifting. Was told timing dropped out and shifting too high. Is it better to run with paddles? Had 93 octane with wmi.
twister68's Avatar
twister68 twister68 is offline
Car: 2017 Q60 RS
Default 10-12-2020, 08:36 AM
thanks Terry, I'll do some longer runs
Twister
2021 Genesis 3.3T
Siberian Ice
JB4 kit with EWGs MAP 2 94RON
Feeling the JB4 difference
Default 10-12-2020, 08:51 AM
Originally Posted by wardyl36
Hi Terry,
Data side seems fine to me. On getting those good times practice makes perfect and weather plays a large role too.
mbr mbr is offline
Car: Cerato GT 1.6T
Default Log check for 1.6T - 10-15-2020, 02:20 AM
Hey Terry, could you please check my log when you've got a sec?
1.6T
map 2
gear 3 (DCT)
regapped stock plugs to 0.24
100RON fuel (5% ethanol)
Fuel wire has been installed but not sure if I got it right, I've also set the DWP to 100 (which has made the car waaay better to drive by the way)
cheers
twister68's Avatar
Car: 2017 Q60 RS
Default Log Check please Terry - 10-16-2020, 03:45 PM
Map 2 94 RON, couple of decent pulls before I go to Map 3 as I just put can of additive in but may not have mixed fully yet as it was only about 20 miles after top up
12.47 1/4 mile and 4.4s 0-60 but still losing on this damn launch but getting better.....4.14s with 1ft roll, too early for brake boost :-)
Twister
2021 Genesis 3.3T
Siberian Ice
Last edited by twister68; 10-16-2020 at 04:35 PM.. Reason: Saved adding another reply
Default 10-18-2020, 08:19 PM
1.6T
map 2
gear 3 (DCT)
cheers
Seems OK to me. On the 1.6L it's harder to tell if the fuel wire is working but the trims seem to be dropping at fuel-enrichment goes up so I'd guess it is.
twister68's Avatar
Car: 2017 Q60 RS
Default Terry - Log File missing from previous post - 10-19-2020, 04:05 AM
Hey Terry - Map 2 with 94 RON & Booster Juice. Can you please take a look to see if all looks well?
thanks
Twister
Twister
2021 Genesis 3.3T
Siberian Ice
mbr mbr is offline
Car: Cerato GT 1.6T
Default 10-19-2020, 03:36 PM
Thanks for that terry, Iím going to have a crack at e30 with map 3 next and see how it goes.
Cheers
Default 10-19-2020, 03:47 PM
thanks
Twister
Looks good to me.
