Mib4289 Mib4289 is offline
Car: 2020 m340ix
Default '20 m340 logs help - 10-15-2020, 07:27 PM
2020 m340iXdrive. Stock with jb4 v17, and 93 octane. I have no experience in reading this and need help understanding which map to run or improvements.
KnifeEdge87 KnifeEdge87 is offline
Car: BMW G30 520i 2019
Default 10-15-2020, 07:41 PM
you're good to go on map3
enjoy
Car: 2020 m340ix
Default 10-15-2020, 08:00 PM
Ok so Don't touch it the numbers are already where the should be?
Default 10-15-2020, 08:17 PM
What numbers?
Map 0 is jb4 off
Map 1 is +3psi
Map 2 is +4psi
Map 3 is +6psi
Your fuel is good enough to run map 3
Car: 2020 m340ix
Default 10-15-2020, 08:25 PM
I was referring to the graphs from my logs and nothing being out of the ordinary or if changes need to be made or adjustments to improve performance from the car.
Default 10-15-2020, 09:15 PM
There are really no adjustments you can make (unless you use a custom map on JB4)
Default 10-15-2020, 09:16 PM
but yes the logs indicate that you would be fine running on map3. everything is ok =D
Car: 2020 m340ix
Default 10-15-2020, 09:27 PM
Thank you. I guess it's time to learn how to read these logs now
