Patches O Hoolihan Patches O Hoolihan is offline
Car: 335xi
Default Unable to change settings on JB4 interface - 10-10-2020, 07:37 PM
Hello,
I drive a 2011 e92 x-drive with an N55 motor / 6 speed manual. I purchased and installed a JB4 unit new back in 2015. I took it off for repairs and left it off until now.
I just installed the JB4 back on except I did the ISO mod to the JB4 unit and uploaded firmware version N55_ISO_5_17_T5.
The ISO mod made a huge difference in consistency. However now I’m dealing with a different issue with 3rd gear only hitting about 7-10psi while 1st, 2nd, and 4th will hit about 18psi on Map 5. So I figured out that I have to change a setting under User Adjustment on the JB4 interface (I’m still using a laptop for connection), but I’m unable to do so. 1st and 2nd Max Boost settings are set to “0” while 3rd gear Max Boost setting is set to “1.” I cannot change it to “0.” Every time I change the value to “0” it just changes back to “1” when I click off the User Adjustment tab and go back.
How can I fix this?
EDIT: I noticed that on the speedo menu I cannot get past 14 on the menu.
Choyo_n55 Choyo_n55 is offline
Car: E90 335i n55
Default 10-10-2020, 11:12 PM
stupid question, but do you click save?
2011 e90 n55, vrsf down pipe,cp,fmic jb4,AT xhp stage3
Car: 335xi
Default 10-11-2020, 05:45 AM
Yes. When I click Save a pop up comes up; Valid Range is 0-100
