(#51)
Default 09-07-2016, 05:18 AM
Quarter mile video of a Golf MK7 R with our Burger Tuning JB1 piggy back unit. Car ran no other engine mods with a different wheel set up to stock. Proof that 12.00 is achievable with a plug and play unit and no hardware mods.
Default 09-19-2016, 03:45 PM
A JB1 user posted some results on the Facebook's.
Car ran in map 1 on 4.8 on 93 octane.
Mods are:
-JB1 piggyback tuning box
-Forge carbon fiber intake
-USP catted ******** with black heat wrap
-Spulen turbo inlet pipe
-Forge turbo muffler delete
-Spulen boost pipe kit
-GoFastBits DV+ diverter valve
-Ecs tuning Turbo blanket
338whp and 346wtq in 82F temps on a 4wd Dynojet. The graph is a bit jagged as they ran 0 smoothing. The norm is 5 which makes the line nice and smooth.
Default 10-12-2016, 03:39 PM
We have a user from Australia that has been trying to get to 11's with no hardware. His previous best was a 12.0.
He went out this weekend and managed it running with no further hardware besides the JB1 on street tires and no weight saving. Car ran on a E85 mix and very consistent.
Alph if you lurking very well done.
Default 10-16-2016, 05:26 PM
Weather is starting to improve and cars at the track are getting faster. Good results from Sam in Michigan. Car ran on stock tires and weight with the JB1 and CTS DP only.
ONDEMAND's Avatar
ONDEMAND ONDEMAND is offline
Car: E82 FBO N55
Default 11-03-2016, 12:02 PM
Curious about the JB1 for my wifes B8.5 A4 2.0T? I see the A3 2.0T mentioned on th burger site but no mention of the A4 2.0T.
Is there an existing JB1 that works with the 2015 2.0T in the A4?
2011 135iCP | 6MT | M-SPORT | PTF Stage2+ | ETS FMIC | BMS DP | BMS CAI | ER CP | 355/454 AT THE WHEELS!
edo edo is offline
Car: E92 335i
Default 11-29-2017, 06:23 AM
would this tune work with the new VW Arteon 2,0 TSI 206 kW (280 PS) 4Motion ?
Any plans to update the product? Almost 2,5 years passed since it was first launched...
Thanks in advance.
Default 11-29-2017, 07:13 AM
Thanks in advance.
The JB1 will be compatible to the Arteon. There is only so much the Jb1 Stage 1 unit can do so there is no point to evolve it. The JB4 has been released in the interim so if you need something more advanced that is the unit of choice.
firemanjust1's Avatar
firemanjust1 firemanjust1 is offline
Car: 2008 BMW 335xi
Default 02-19-2018, 12:30 AM
Hi George is the BMS JB4 bluetooth connect kit compatible with the rev2 JB1 for my Audi S3, thanks in advance ?
JB4/G5 ISO ,AR DP,BMS DCI,NGK 5992 BMS Meth kit dual nozzle CM 7 & 5,VRSF 7 IC, Stett chargpipe, E60 mix, 255 Walbro, Bms Race flash. RB turbos , VTT inlets ,BMS OCC, 3.5 N20 sensor, Conti DWS
Default 02-19-2018, 05:12 AM
Hi, it can be used on the JB1. You will be limited to boost display only and map switching and map editing. Rest of the features are JB4 only.
blackout1231 blackout1231 is offline
Car: 2014 Jetta GLI Edition 30
Default 03-16-2018, 12:36 PM
I have these codes on my JB4 app, I've no issues currently with my or or warning lights, but am not sure what they mean or if I should look into them or not...
3A41 NO DESCRIPTION FOUND
3B60 NO DESCRIPTION FOUND
0000 UNKNOWN FAULT
2000 NO DESCRIPTION FOUND
0020 NO DESCRIPTION FOUND
0000 NO DESCRIPTION FOUND
I've done some reading on the internets, but have not found any useful information.
Default 03-16-2018, 12:51 PM
0000 UNKNOWN FAULT
Those are overboost related. If it doesn't trigger the light I wouldn't be concerned.
Default 03-16-2018, 01:21 PM
I have a CTS Turbo DV, going to look into that and make sure it is working properly in the meantime (pretty sure it is).
Thanks for the reply!
black_mamba_s3 black_mamba_s3 is offline
Car: 2018 Audi S3
Default new purchases - 05-08-2019, 09:12 AM
Hi George,
I'm looking at the JB1 over the JB4 as I'm not planning on doing anything other than the tune. I've just changed the air filter to a high flow K&N filter maybe that'll help a bit.
My question is, will the JB1 come with the most up to date firmware when I buy it, or is it up to me to purchase the wires and do it manually upon delivery?
Also, I've read many previous posts but none show anything recent for a stock 2018 S3 running the JB1. With my year (2018 8V), am I still looking at 35whp gains? or is it more? is it also more stable than I've read previous firmwares were?
Thanks for your help!
Default 05-08-2019, 11:14 AM
Originally Posted by black_mamba_s3
Hi George,
The 35whp is very conservative and the cars produce quite a bit more.
The JB1 is a basic unit and we haven't had the need to do firmware updates with it so if you plan to just plug and play the data cable is not needed.
Car: 2018 Audi S3
Default 05-08-2019, 11:45 AM
That's awesome, exactly what I was hoping to hear!
Given the fact that I'm not doing any other mod to the car, is there a difference in gains between the JB1 and the JB4 ?
Default 05-08-2019, 01:20 PM
Ultimately the JB4 will give you more power if you get involved in customizing the maps with us. For something you just want to fit and forget there is a very small difference between the two.
Default 10-05-2020, 02:58 PM
Does anyone know what the error code "3B54" is by any chance?
I've recently been getting an EPC light when accelerating (mainly in sport mode), and when the light comes on I lose power.
