JeepRage JeepRage is offline
Car: Audi
Default Unable to Connect to B9 SQ5 - failed port not found or busy - 09-17-2020, 01:04 PM
I've followed directions here: N54Tech.com - International Turbo Racing Discussion - View Single Post - JB4 laptop connection directions
JB4 is installed, I've hit Run twice to turn on power but not the car.
Downloaded and installed drivers, set Com port to 3 (confirmed in Device Manager), set under Settings. I click Connect and unable to and unable to see Map.
I've tried 2 computers, using the Beta software interface, double checked ground, connections, serial to board connection, all USB ports, etc.
No matter what I do, I get: failed port not found or busy Com 3.
I'm at wits end. What to do next? I don't want to regret the purchase before I even get it running.
Car: Audi
Default 09-17-2020, 01:26 PM
I'm getting: Port not found or busy: Com 3
Default 09-18-2020, 04:54 AM
See contact on your email.
Car: Audi
Default 09-18-2020, 10:13 AM
Thanks, I responded with info.
Car: Audi
Default 09-23-2020, 04:09 AM
I received and swapped cables (thanks), but still unable to connect to the JB4. I am getting: Failed port not found or busy message.
I've installed drivers, connected to JB4 via USB, opened JB4, confirmed port of Device Manager and selected it, and turned accessories on but car not running. What is my next step? I've tried to connect on 2 different computers and got the same message. Can you link me to the correct JB4 software to ensure I'm using the right version if that is a factor? I tried both original and beta version on Audi thread.
Separately, over the weekend I got a driveline malfunction message and a CEL, both eventually went away. The unit is as shipped, assuming Map 1 since I cannot connect. All connections are made (even the optional) on a 2018 Audi SQ5, including OBD2 port.
2018 Audi SQ5
Default 09-23-2020, 08:31 AM
We will need to swop out the master chip. See email sent.
