Sr34sr Sr34sr is offline
Car: Kia stinger GT1
Default Map 2 log check - 09-13-2020, 09:22 PM
Gt1 3.3
Custom intakes with dual AEM filters
93 octane shell gas.
Apologies if this is not the way to upload logs from a phone.
My main concern is with a timing discrepancy on cylinder #1 repeating a few times...I understand that cylinder #1 is sampled differently from the others so I'm hoping that's the issue. Afr on both banks match well albeit this tune has quite a lean tip into boost. I've seen areas with 14:1+ afrs while seeing over 10psi in second gear spooling up. Will run vp octanium tomorrow to see if cylinder #1 stops reading oddly from the rest.
Looking forward to your opinion Terry.
Thanks.
Oh and I've only got about 35 mins worth or driving with the jb4 and my custom intakes installed same time.
Default 09-15-2020, 01:59 PM
Seems fine to me here, timing is generally matching up between cylinders. Octane booster will certainly improve things a bit.
Default 09-17-2020, 06:21 PM
