2016n55 2016n55 is offline
Car: 2016 bmw 435i
Default JB4 map 2 19 psi of boost - 09-06-2020, 10:46 AM
2016 435i N55 with ppk
- Chargepipe
- 94 octane
- 2 step colder spark plugs
- ER high flow down pipe
I launched my car twice yesterday once on map 2 and once on map 5 the map 2 was pushing 19 lbs of boost and on map 5 I was hitting around 18 and then it swaped into map 4
both logs for the launches are attached. also attached my settings only changed the ff from 70 down to 50
Car: 2016 bmw 435i
Default attachments - 09-06-2020, 10:48 AM
here are the files they didnt go through in the main post and cant edit it
Default 09-09-2020, 07:32 PM
I’d assume you are just hitting your boost safety, up that & problem should
Go away.
Car: 2016 bmw 435i
Default 09-09-2020, 07:47 PM
ya I was wondering why the boost was so high in map 2 though but everything seemed to go down once I added an air intake
Default 09-11-2020, 05:09 PM
enjoy the weekend
